virtual worlds
Hi I have installed the starstruck software for virtual worlds but i can’t select to use and the sample programs doesn’t appears to try out the game.
so, what can I do to fix it.
First you need to go to the robot tab -> compiler target ans select virtual worlds. Then you go to the windows tab that’s to the right of the robot tab; select window -> select virtual world -> (if everything installed correctly) starstruck should appear in that list. After this to download a sample program go to the file tab -> open sample programs -> in the list it brings up there is a vex starstruck file near the bottom, select it and then you should have 4 sample starstruck programs that you can choose from.
