Void Function Problem, Function definition is not allowed here
Im very new to the whole programming gig and I wanted to test out code that would allow me to actually program in distances for our autons. I asked around and I got some sample code but there is an error saying “Function definition is not allowed”
Heres the portion of the code where the error is:
const float WHEEL_DIAMETER = 4;
const float WHEEL_CIRCUMFERENCE = WHEEL_DIAMETER * 3.1416;
const float GEAR_RATIO = 1;
const int AUTON_DRIVE_PCT = 50;
void driveForward(float inches) {//The error is right here
float inchesPerDegree = WHEEL_CIRCUMFERENCE / 360;
float degrees = inches / inchesPerDegree;
LDF.startRotateFor(degrees * GEAR_RATIO, vex::rotationUnits::deg,
                   AUTON_DRIVE_PCT, vex::velocityUnits::pct);
LDB.startRotateFor(degrees * GEAR_RATIO, vex::rotationUnits::deg,
RDF.rotateFor(degrees * GEAR_RATIO, vex::rotationUnits::deg,
RDB.rotateFor(degrees * GEAR_RATIO, vex::rotationUnits::deg,
you probably define a function in another function. Show your whole code with enclose by with “```”
Heres everything leading to the user control, sorry my computers slow and would take forever to paste everything
Module: main.cpp /
Authors: Vivek Patel /
Created: Sun Dec 22 2019 /
Description: Competition Template /
// Robot Configuration:
// [Name] [Type] [Port(s)]
// LimitSwitchA limit A
// Inertial inertial 12
#include “vex.h”
using namespace vex;
competition Competition;
/* Pre-Autonomous Functions */
void pre_auton(void) {
vexcodeInit();
vex::inertial Inertial(vex::PORT12);
Inertial.calibrate();
while (Inertial.isCalibrating()) {
wait(100, msec);
/* Autonomous Task */
void autonomous(void) {
// Drive Motors
vex::motor RDF(vex::PORT10, vex::gearSetting::ratio18_1, false);
vex::motor RDB(vex::PORT20, vex::gearSetting::ratio18_1, true);
vex::motor LDF(vex::PORT1, vex::gearSetting::ratio18_1, true);
vex::motor LDB(vex::PORT11, vex::gearSetting::ratio18_1, false);
// Lift Motors
vex::motor LL(vex::PORT13, vex::gearSetting::ratio36_1, true);
vex::motor RL(vex::PORT19, vex::gearSetting::ratio36_1, false);
// Intake Motors
vex::motor CLR(vex::PORT6, vex::gearSetting::ratio36_1, false);
vex::motor CLL(vex::PORT3, vex::gearSetting::ratio36_1, false);
// Inertial
// Controller
vex::controller Controller1 = vex::controller();
/* User Control Task */
you define
inside
just move the definition of function driveForward outside of pre_auton
Yeah I think I just got it to work, thanks a bunch I didn’t realize that could’ve been the issue. Forum works magic
