I have downloaded the activity answer key, but cannot open it on my Chromebook. I’ve tried to open directly with no luck. I uploaded into Google Drive, then unzipped, but it will open in a usable way.
Suggestions?
I have just checked from Windows and the zip file contains 2 folders, one Blocks and one Python each with the associated vrblocks or vrpython files in.
I think Chromebook default file system handles zips a bit differently in that the zip file gets mounted as a drive and you then open that drive to view the files inside it.
Hi @Robert_King Here is a knowledge base article that outlines the process. Please let us know if this helps: https://kb.vex.com/hc/en-us/articles/360042411611-Teacher-Portal-Educator-Resources-VEXcode-VR
Thanks
