Way To Bypass Vision Sensor Limit
Is there a way to bypass the Limit of being able to only run 1 Vision Sensor on the IQ Brain? Do I have to manually configure them in the code, or is there a software cap that only will take the first one configured? I would like to use 2 Vision Sensors, but I just want to make sure that I can do so with unmodified firmware before writing the code. As I cannot test any ideas because I do not have a brain on me. I would be doing this on a Gen 2 brain if that would change anything.
Thanks!
-Blaziumm
you can use more than one vision sensor, but you will need to create instances of them with code not using the graphical setup. Probably not such a great idea on IQ generation 1 due to memory limitations.
