Hi,
This is our intake:
Discs get stuck if more than one goes up. How would you make it stronger?
Many thanks,
23218Z
Hi,
This is our intake:
Many thanks,
23218Z
Reducing friction would help. A good way to do this on your design is to take off the topmost 3" flex wheel. Your shooter seems to be a lot lower than the top of the intake. The purpose of the intake is to transfer discs from the floor to the shooter, so there is no reason to move the disc to that height. If that top wheel is used for rollers, then u can still have it for rollers by chaining it to your intake. Removing the top wheel and cutting the polycarbonate shorter will remove an axle, therefore removing some friction. A shorter intake also has less of a chance for 2 discs to be in it at the same time.
What is your intake speed?
