I was just wondering what are the common robot designs
u mean what is the meta for this year. looks like tray, claw, or lift. one of yal correct me if im wrong
Maybe check out this thread?
What do you mean by claw?
Also the meta combination of robot seems to be a 4bar or something like that paired with a good traybot that is the best combination of robots on the field.
Check 21000C
20 char
search 21000C Tower Takeover Hawaii Reveal on the forums. this is clawbot @enothecool
these are some of the more common designs I’ve seen so far. This is the biggest meta design at the moment.
VEX 2019 Tower Takeover RI3D Reveal
It’s typically on a all Omni direct drive, due to that being the easiest and simplest design. I’ve also seen some X-drives popping up due to increased mobility.
The next biggest design looks like this
Good at towers but gets outpaced in stacking by the previous meta. DR4B are the most prominent lift due to the high speed and decent torque. I’ve also seen a scissor lift from 62.
Team 62 Vex Tower Takeover 2019 Early Season Teaser
Scissors are harder to build, and slower, but they are typically pretty strong. Personally I think the best of these three is the 448X tilter design due to speed and versatility, but a good DR4B can be very competitive.
Well if that is what he means by claw, then what is lift?
Lift i believe stays on floor. U see with 21000 their lift is in air. Meaning it a claw
