What gear cartridge should I use for a 6 motor drivetrain
Does anyone have a recommended motor cartridge I should use for a 6 motor drive? And what ratio I should make the gears to the drive
Blue cartridge 600rpm is easier to gear. As long as you have a drive speed above 300rpm you should be fine.
It’s generally easier to make a drivetrain with blue cartridges because there’s more ratios available. They also have less friction and slop because they have less gearing inside compared to green and red ones.
Also remember to do some research before asking a question, you might find a thread like this one which would give you an answer much faster then waiting for a response:
