Where can I find out more about the Vex_all_timers.lib and and Vex_all_timers_wauton.lib libraries, whats inside for reference?
**Look inside the ifi_default.h file for the following section:
FUNCTION PROTOTYPES
/* These routines reside in ifi_library.lib */
Use this as a reference since all of our libraries are basically the same. You are given an explanation of the routines that are called inside the libraries. The code for the routines that are called will not be released.**
Ricky Torrance
Electrical Engineer
VexLABS
