Also you don’t need to practice driving with your robot at all. If you’re a good enough driver you’ll be a god at driving it as soon as you touch the controller
Don’t bother turning in an EN
That’s exactly what the guys on my team thought. No wonder we came in last place at our most recent comp.
1 motor drive is better!
All I can say is im sorry for you .-.
Heh, they learned their lesson.
That’s what robotics is all about, also I said that because my team has put A LOT of effort into our provincials robot and just because it’s not working right now my teammate wants to scrap it and build a new one
Ean writes: Using rivets
This. I deliver VEX EDR kits to teams and as we unpack, I grab the rivets and take them and give them three bags of screws of different sizes and three bags of nuts (one is nylock) problem solved.
Worst is “add weight” to help an out of balance / topple over issue. Ugg…
(* I used to throw the rivets in the trash but I had a Teacher/Mentor “rescue” them and the team used them. /sigh So now I take them and put them in my recycling.
Use a steering system
Make it robot that makes stacks by lifting a stack and sliding cubes underneath
Use standoffs as screw extendors
Don’t use screws to fasten anything together, instead just cut a lot of short shafts and put shaft collars on both sides to tighten them together.
use stand-offs instead f regular nuts. Also the new v5 system is way worse than cortex so use cortex
Use VEX coding studio.
Always take my advice.
screws are kinda bad ngl, just use axles for everything
This is actually good advice.
throw auto win the match…
Don’t run skills or turn in EN notebook. Don’t worry you will still get awards.
dont make a robot and just watch memes and the sun is a deadly lazer 16 million times
Just have your robot loop around the field like a drag racer
Thats the best advice I have ever heard.
