The 1 seed.
Hole counters.
Cat on the field.
WHY DOES THE ROBOT STOP WORKING ON COMPETITION DAY?
WHY DOES THE AUTONOMOUS CROSS THE LINE NOW? WHY CANT THE ROBOT JUST DO THE THING?
The 1 seed.
Hole counters.
Cat on the field.
2v1’s in LRT bc they don’t exist
My Kryptonite in robotics is the same as in real life. I’m a horrible snack-retriever. To fix this, my team last year had The Intern. He was a rookie that didn’t really want to be there, so he memorized our Starbucks orders, and randomly brought us snacks. He was awesome.
My Kryptonite would probably be the maintenance of our robot. There always seems to be a screw loose or a piece out of alignment, or a shaft out of our motor, or a shaft collar thats fallen off. I can never find it but the rest of my teammates can like it’s blatantly obvious.
Time
Which I have used on V5 robots and to fasten a run of Ethernet cable in my workshop. Round head wood screws to hold them to the wall.
Levers
My partner disconnected and we got 0 points for them. If they just hadn’t moved the entire match, we would’ve won with the points from the starting position
Being good is my kryptonite
Same it would probably be the maintenance for the robot too.
You mean your partner actually cost you points? I can relate. I completed homerow in auton and my qual partner somehow decided to remove balls, so I didn’t get homerow bc they scored negative points. I was not a happy camper
One word, Axels. A major flag in my old robot design for change up.
honestly, i hate programming auton, and watching it fail. im not even the programmer and i still hate it.
Reverse double 4bl. I just don’t like them
I feel your pain. Programming auton Is horrible not only for the programmer, but for the other team members as well because it never works and when you do get it to work, it isn’t on time so only one part of the auton works.
Having to fix a build problem when I don’t have builders nearby.
Me being the only person on my team: I can’t blame anybody for something.
Except for my battery. > : )
Getting the full force of the team’s anger rained down on you after the auton doesn’t work because they chose the wrong one
One time my code was working perfectly and suddenly we get to the finals match. I hadn’t even touched my code and suddenly my drivetrain controls were inverted
