What to put on a flywheel
What is the best to put on one single flywheel I have seen rubber bands,zip ties,mat,screws, what will be the best for a single wheel single fly wheel
I have seen teams use zip ties to stop the rubber on the wheel from warping and coming off at high speed (although I have personally had no problems with this) as well as using rubber bands for the reasons described in this thread.
Depends on the type of wheels you are using for your flywheel.
I just like using the wheel alone if possible. anything you put on the outside of the wheel would alter accuracy and can shift the balance of the wheel and cause it to shake too much.
thanks im using a single 5in green wheel brand new
Best?! Can you explain your problem? I would not use screws. Sounds dangerous/ hazardous.
