Hello, any good ideas for intakes? I have tried everything - intake rollers, tank treads with flaps, and all sorts of wheels. Any advice?
Do you have any reoccurring issues? Compression? Cube alignment?
mainly compression issues. The cubes either slide out or can’ t come out at all. I tried moving the intakes out one space but then they just slide out.
If your intake is static then yeah you’ll have problems with that. Most trays are fairly loose and are rubber banded inward to compress the cubes while still allowing the arms to open up a bit to realign the cubes.
But they have a piece of metal or something stopping them from flexing inward. Also sprocket size seems to matter.
