What Type of Snailbot is Best
I would argue that having a pooper is better overall:
You can still do all of the strategies that a robot without a pooper could because you do not have to poop.
A robot with a pooper is more adaptable as it allows you to conform they way you play to fit the opponent. If you want to be able to eject the balls during a game you can, but you can also choose to not eject the balls.
The only thing you lose is a minor loss in cycle speed and chain breakages; both of which can be negated with good build quality.
Basically, I believe that a robot with a pooper is much more versatile in competition; you can eject the balls, or you can leave them in the goal. This is what makes the pooper more useful (imo) than a robot without one, as it can adapt to your opponents strategies.
Having a pooper means that you can do basically everything that @Xenon27, and @Ryan_4253B said, surely thats better than only being able to do only one of those things!
Tbh, I would strongly doubt that your arguments will be a problem for this year’s competition.
  1. The drivers can simply “poop” the balls where it will be hard for the opponent to get them. Also, pooper doesn’t mean no de-scoring. If the driver is good enough, (FYI our driver is phenomenal) you can make row points and poop balls at the same time.
  2. Efficiency. You can just de-score the opponent’s ball and throw it out on the side or just keep it, but depending on your strategy, pooping out balls might make things faster and easier.
  3. I don’t get how pooper loses efficiency. If the spinners are fast enough, cycle time will be the same as just a regular snailbot. What’s more, it the gear ratios are done right, it might be faster than normal snailbots.
  4. Not if you have a good programmer. We can just do multiple trials and perfect the code. Although during autonomous, I don’t think pooping will be necessary.
  5. First, I wasn’t telling you that you should use it. Also, chains don’t always break. But if it’s really risky, then we can just use gears instead of chains.
No offense, but I don’t think you should state “The best design for a snail bot is just a simply 3 ball capacity ones with extremely fast cycle time.” like it’s a fact. There can be other designs that are better. Also, the hood that is a piece of straight plastic rather than a rounded piece connected to the spinners will increase the accuracy when shooting the ball really fast. Good luck on your season too, see you at Worlds.
oh surely we’ll meet sooner than that. Be sure to check out location in the profile page :eyes: :eyes:
Huh, so are you in high school? If you were in middle school I would know you.
yes, I am indeed an high schooler, as you can see from the team number.
Nice to meet you! We go to the same school! I’m in seventh grade though.
