Whats wrong with this is keeps saying they same thing "**Error**:Unexpected '}' during parsing"
#pragma config(Motor,  port1,           leftMotor,     tmotorVex393_HBridge, openLoop, reversed)
#pragma config(Motor,  port3,           backMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port6,           clawMotor,     tmotorVex269_MC29, openLoop, reversed)
#pragma config(Motor,  port7,           armMotor,      tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor,  port9,           sideMotor,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port10,          rightMotor,    tmotorVex393_HBridge, openLoop)
|*                                - Clawbot Single Joystick Control -                                 *|
|*                                      ROBOTC on VEX 2.0 Cortex                                      *|
|*  This program uses a single joystick, either right or left to drive the robot. Use notes below     *|
|*  to reconfigure which joystick is used. The joystick buttons are used to raise and lower the arm.	*|
|*  The joystick buttons are used to open and close the claw.																					*|
|*                                        ROBOT CONFIGURATION                                         *|
|*    NOTES:        *|
|*    1)	Ch1 is the X axis and Ch2 is the Y axis for the RIGHT joystick.                             *|
|*    2)	Ch1 is the X axis and Ch2 is the Y axis for the RIGHT joystick.                             *|
|*		3)	Button 5U and 5L are on the front left side of the joystick.																*|
|*		3)	Button 6U and 6L are on the front right side of the joystick.																*|
|*    4)  Ch3 is the X axis and Ch4 is the Y axis for the RIGHT joystick.                             *|
|*    5)  Ch3 is the X axis and Ch4 is the Y axis for the RIGHT joystick.                             *|
|*    MOTORS & SENSORS:        *|
|*    [I/O Port]        [Name]          [Type]                               [Description]            *|
|*    Motor - Port 2   rightMotor    VEX 393 Motor                         Right drive motor          *|
|*    Motor - Port 6   clawMotor     VEX 393 Motor w/ Motor Controler 29   Claw motor                 *|
|*    Motor - Port 7   armMotor      VEX 393 Motor w/ Motor Controler 29   Arm motor                  *|
|*    Motor - Port 10  leftMotor     VEX 393 Motor                         Left drive motor 					*|
|*    Motor - Port 3   backMotor     VEX 393 Motor                         Back right drive motor     *|
|*    Motor - Port 9   sideMotor     VEX 393 motor                         Back left Drive motor      *|
//+++++++++++++++++++++++++++++++++++++++++++++| MAIN |+++++++++++++++++++++++++++++++++++++++++++++++
task main ()
	while(1 == 1)
		motor[leftMotor]  = (vexRT[Ch2] + vexRT[Ch1])/2;  // (y + x)/2
		motor[rightMotor] = (vexRT[Ch2] - vexRT[Ch1])/2;  // (y - x)/2
		while (4 == 4)
			motor[backMotor] = (vexRT[Ch3] + vexRT [Ch4])/3;  // (y + x)/3
			motor[sideMotor] = (vexRT[Ch3] - vexRT [Ch4])/3;  // (y - x)/3
		// Raise, lower or do not move arm
		if(vexRT[Btn5U] == 1)       	//If button 5U is pressed...
			motor[armMotor] = 127;    	//...raise the arm.
		else if(vexRT[Btn5D] == 1)  	//Else, if button 5D is pressed...
			motor[armMotor] = -127;   	//...lower the arm.
		else                      		//Else (neither button is pressed)...
			motor[armMotor] = 0;      	//...stop the arm.
		// Open, close or do not more claw
		if(vexRT[Btn6U] == 1)       	//If Button 6U is pressed...
			motor[clawMotor] = 127;  		//...close the gripper.
		else if(vexRT[Btn6D] == 1)  	//Else, if button 6D is pressed...
			motor[clawMotor] = -127; 		//...open the gripper.
			motor[clawMotor] = 0;    		//...stop the gripper.
your braces are not balanced, both while loops have both opening and closing braces {}, so that’s not going to work, then you will be missing one final brace.
Use indentation to format the code and it should be pretty obvious.
I will try that in 10 min when I go there
and I only in 10th grade how this is my first time coding
it says there only something wrong with the last brace
it’s say their something wrong with that brase
