does anyone know how to reduce a v4 claw bot wheels wobble?
Make sure you are using delrin bearings* and shaft collars*. Using those should make it more sturdy. However, for more help, pictures of the drivetrain could be useful.
- pictures below.
if you are still using the base clawbot design you need to support the wheels from both sides instead of just one as the clawbot is.
i shall try that first th8s
Also, make sure it has the green and grey axle inserts installed on both sides, not just one side.
Also, just as a heads up, I think this should be in the VEX EDR category of the forums @vex-net-questions2
thanks
sir/ madam
ima try that
