Where the calculator for skills?
Does anyone know where I can find the calculator for skills? Vex hub doesn’t seem to have it, and I was wondering if anyone has made one yet.
The calculator can be found on the V5RC hub app
Where’s the calculator for skills matches though?
It doesn’t really exist as you need to just add the 5 points per goal in corner and just pretend you have a red ring on the blue alliance stake and vice versa. Best solution is to us the vexhub score and then manually check corners and alliance stakes.
Thanks! Also, during a skills match when there’s already one blue ring on two mobile goals, you already have and automatic 6 points right? That’s what I’m understanding from the manual.
Sadly no
Blue Rings may only be Scored as Top Rings on Stakes. Each Blue Ring only has a point value if: At least one red Ring is Scored below the blue Ring on that Stake. No red Rings are Scored above the blue Ring on that stake.
So to get those rings scored you have to somhow get a red ring under the blue ring and score all other red rings. Those mobile goals do still count for 5 pts if you put them in corners though so it is better to score all the rings on the other 7 stakes and just get the 10 pts from shoving thoes mogos in the corners.
Thanks a lot for your help !
Sounds like an email to DWAB is in order :​)
