Im sorry if im missing it, but where can i configure the vision sensor using the V5 Vision Utility program? where do i download/ start the V5 Vision Utility program
It will typically be installed with whatever development environment you use. What are you using?
On some operating systems, PROS doesn’t ship with a Vision Utility. You can either use VCS’s vision utility or RobotMesh’s vision utility.
Im using PROS to program my vision
Oh so they work like the same right?
But when i install pros, i remember seeing a checkmark for downloading the v5 vision uttility
PROS does come with a vision utility. You can download it separately here:
Windows MacOS
Where i got them from
(though note, I believe the pros vision utility has an extra feature to copy signatures)
Where can i access that vision utility that came with pros?
Try searching on your computer for “vision utility” or something similar. You downloaded the right file; that’s the PROS installer for the latest version.
i searched my whole C: for v5 vision utility and it only showed a vcs vision utility (lol)
That’s the one. It’s not listed as “PROS vision utility” or anything if that’s what you mean.
oh ok my searched file is at C:\Users\Eden Cheung\AppData\Local\Programs\PROS\v5-vision many Thanks!
The ones on our releases page are the same ones that would get installed through other means, so they should also have that copy button.
