Which direction is up after a robot has rotated? <SG3> <SG10>
Hi Karthik,
In this thread:
You said:
If a robot has rotated from its starting configuration about an axis parallel to the field surface (in a way that forces its imaginary 18” cube to rotate with it to keep the robot in size) then which direction is the ‘18" height limit’ measured in? Does the ‘height’ direction rotate with the imaginary cube?
EDIT: our team talked a bit about how this could easily get complicated. One way that would be relatively simple to enforce would be to make the sizing requirement that the robot has to EITHER fit completely within an 18" cube that can rotate OR be completely within a 2’ x 2’ x 18" cuboid that sits so that it completely covers the Climbing zone. The cuboid would be able to move up and down, but not move horizontally or rotate.
