I am attempting to have my claw oscillate while the intake is running, I assumed a while loop would work yet it seems to not be running the while loop even if the conditions are met.
Code-
I suspect you think isSpinning() means the motors are moving. isSpinning() is only true when the motor is moving to a target position, ie. a spinFor or spinTo is still executing.
A while loop is a yielding function. That basically means that anything in a while() would run and nothing outside of the while() will run, so long as the condition is met. In driver control you traditionally only have one while loop. I believe you should be only using an if statement. Also if the motor is spinning I am unsure if it is not your intention to command the motor to spin for 60 degrees every 5 or so milliseconds because that is what the code is doing in the inner while loop.
