Why can't my robot turn backwards after turning 90 degrees?
I am using pros and lemlib to code autonomous. After a move to point function followed by a turn to heading function, my robot refuses to move backwards. Can some please me? Thanks`#include “main.h”
#include “lemlib/api.hpp” // IWYU pragma: keep
using namespace pros;
using namespace lemlib;
pros::MotorGroup right_mg({14,11,-17},pros::MotorGearset::blue);
pros::MotorGroup left_mg({4,-5,-10},pros::MotorGearset::blue);
pros::adi::Pneumatics mogoalclamp(‘a’,false);
pros::adi::Pneumatics doinker(‘b’,false);
pros::MotorGroup elevator_mg({-3,12});
pros::MotorGroup wallstakes_mg({-19});
pros::Rotation ws_rotation({8});
pros::Rotation vertical_encoder(2);
pros::Rotation horizontal_encoder(6);
lemlib::Drivetrain drivetrain(&left_mg,&right_mg,12.9,lemlib::Omniwheel::NEW_325,360,2);
pros::Imu imu(1);
lemlib::TrackingWheel horizontal_tracking_wheel(&horizontal_encoder, lemlib::Omniwheel::NEW_2, 1);
lemlib::TrackingWheel vertical_tracking_wheel(&vertical_encoder, lemlib::Omniwheel::NEW_2,2);
lemlib::OdomSensors sensors(&vertical_tracking_wheel,nullptr,&horizontal_tracking_wheel, nullptr,&imu);
// lateral PID controller
lemlib::ControllerSettings lateral_controller(21, // proportional gain (kP)
0, // integral gain (kI)
4, // derivative gain (kD)
0, // anti windup
0, // small error range, in inches
0, // small error range timeout, in milliseconds
0, // large error range, in inches
0, // large error range timeout, in milliseconds
20 // maximum acceleration (slew)
lemlib::ControllerSettings angular_controller(6, // proportional gain (kP)
30, // derivative gain (kD)
0, // anti windup
lemlib::Chassis chassis(drivetrain, // drivetrain settings
lateral_controller, // lateral PID settings
angular_controller, // angular PID settings
sensors // odometry sensors
  • A callback function for LLEMU’s center button.
  • When this callback is fired, it will toggle line 2 of the LCD text between
  • “I was pressed!” and nothing.
    void on_center_button() {
    static bool pressed = false;
    pressed = !pressed;
    if (pressed) {
    pros::lcd::set_text(2, “I was pressed!”);
    } else {
    pros::lcd::clear_line(2);
  • Runs initialization code. This occurs as soon as the program is started.
  • All other competition modes are blocked by initialize; it is recommended
  • to keep execution time for this mode under a few seconds.
    void initialize() {
    pros::lcd::initialize();
    pros::lcd::register_btn1_cb(on_center_button);
  • Runs while the robot is in the disabled state of Field Management System or
  • the VEX Competition Switch, following either autonomous or opcontrol. When
  • the robot is enabled, this task will exit.
    void disabled() {}
  • Runs after initialize(), and before autonomous when connected to the Field
  • Management System or the VEX Competition Switch. This is intended for
  • competition-specific initialization routines, such as an autonomous selector
  • on the LCD.
  • This task will exit when the robot is enabled and autonomous or opcontrol
  • starts.
    void competition_initialize() {}
  • Runs the user autonomous code. This function will be started in its own task
  • with the default priority and stack size whenever the robot is enabled via
  • the Field Management System or the VEX Competition Switch in the autonomous
  • mode. Alternatively, this function may be called in initialize or opcontrol
  • for non-competition testing purposes.
  • If the robot is disabled or communications is lost, the autonomous task
  • will be stopped. Re-enabling the robot will restart the task, not re-start it
  • from where it left off.
    void autonomous() {
  • Runs the operator control code. This function will be started in its own task
  • the Field Management System or the VEX Competition Switch in the operator
  • control mode.
  • If no competition control is connected, this function will run immediately
  • following initialize().
  • operator control task will be stopped. Re-enabling the robot will restart the
  • task, not resume it from where it left off.
    /*pros::MotorGroup right_mg({-14,-11,17},pros::MotorGearset::blue);
    wallstakes_mg.set_brake_mode_all(pros::E_MOTOR_BRAKE_HOLD);
    pros::Imu imu(1);
    lemlib::TrackingWheel horizontal_tracking_wheel(&horizontal_encoder, lemlib::Omniwheel::NEW_2, 3,2);
    lemlib::TrackingWheel vertical_tracking_wheel(&vertical_encoder, lemlib::Omniwheel::NEW_2,2,3);
    lemlib::ControllerSettings lateral_controller(10, // proportional gain (kP)
    3, // derivative gain (kD)
    3, // anti windup
    1, // small error range, in inches
    100, // small error range timeout, in milliseconds
    3, // large error range, in inches
    500, // large error range timeout, in milliseconds
    // angular PID controller
    lemlib::ControllerSettings angular_controller(2, // proportional gain (kP)
    10, // derivative gain (kD)
    3, // anti windup
    1, // small error range, in degrees
    3, // large error range, in degrees
void opcontrol() {
pros::delay(1000);
chassis.calibrate();
chassis.setPose(0, 0, 0);
chassis.moveToPoint(0, -0.9, 1000, {.forwards = true, .maxSpeed = 50}, true);
pros::delay(1000);
chassis.turnToHeading(90, 1000, {.maxSpeed = 50}, true);
pros::delay(1000);
chassis.moveToPoint(0, 2, 1000, {.forwards = false, .maxSpeed = 50}, true);
pros::delay(1000);
chassis.moveToPoint(-2, 0.9, 1000, {.forwards = false, .maxSpeed = 50}, true);
/*pros::Controller master(pros::E_CONTROLLER_MASTER);
pros::MotorGroup right_mg({-14,-11,17}); // 14,11,17 // Creates a motor group with forwards ports 1 & 3 and reversed port 2
pros::MotorGroup left_mg({4,-5,-10});//4,5,10
pros::adi::Pneumatics mogoalclamp('a',false);
pros::adi::Pneumatics doinker('b',false);
ws_rotation.set_reversed(true);
ws_rotation.reset();*/
//while (true) {
	//pros::lcd::print(0, "%d %d %d", (pros::lcd::read_buttons() & LCD_BTN_LEFT) >> 2,
	                 //(pros::lcd::read_buttons() & LCD_BTN_CENTER) >> 1,
	                 //(pros::lcd::read_buttons() & LCD_BTN_RIGHT) >> 0);  // Prints status of the emulated screen LCDs
	// Arcade control scheme
	/*int turn = master.get_analog(ANALOG_LEFT_Y);    // Gets amount forward/backward from left joystick
	int dir = master.get_analog(ANALOG_RIGHT_X);  // Gets the turn left/right from right joystick
	left_mg.move(dir - turn);                      // Sets left motor voltage
	right_mg.move(dir + turn);                     // Sets right motor voltage
	if (master.get_digital(pros::E_CONTROLLER_DIGITAL_L1)){
		mogoalclamp.set_value(true);
	}else if(master.get_digital(pros::E_CONTROLLER_DIGITAL_L2)){
		mogoalclamp.set_value(false);}
	if (master.get_digital(pros::E_CONTROLLER_DIGITAL_R1)){
		elevator_mg.move(500);
	}else if(master.get_digital(pros::E_CONTROLLER_DIGITAL_R2)){
		elevator_mg.move(-500);}
	else{
		elevator_mg.brake();
	if (master.get_digital(pros::E_CONTROLLER_DIGITAL_UP)){
		doinker.set_value(true);
	}else if  (master.get_digital(pros::E_CONTROLLER_DIGITAL_DOWN)){
		doinker.set_value(false);}
	else if (master.get_digital(pros::E_CONTROLLER_DIGITAL_X)){
		wallstakes_mg.move(80);
	}else if (master.get_digital(pros::E_CONTROLLER_DIGITAL_B)){
		wallstakes_mg.move(-80);
	}else if (master.get_digital(pros::E_CONTROLLER_DIGITAL_Y)){
		pros::lcd::print(0, "%d %d %d",ws_rotation.get_angle());
		while (ws_rotation.get_angle()<35076){
			wallstakes_mg.move(80);}
		wallstakes_mg.brake();
	}else if (master.get_digital(pros::E_CONTROLLER_DIGITAL_A)){
		ws_rotation.reset();}
	else{
	if (master.get_digital(pros::E_CONTROLLER_DIGITAL_RIGHT)){
	elevator_mg.move_absolute(-30,-20);
	//pros::delay(20);
