When I set my motor to go 271.2 degrees the motor stops at 72 degrees. I set the starting point of the code to 0 degrees.
using namespace vex;
int main() {
vexcodeInit();
Arm.setVelocity(50,percent);
FrontLeft.setVelocity(100, percent);
FrontRight.setVelocity(100, percent);
BackLeft.setVelocity(100, percent);
BackRight.setVelocity(100, percent);
Arm.setPosition(0, degrees);
Arm.setStopping(hold);
while(true){
FrontLeft.spin(vex::directionType::fwd, (Controller1.Axis3.value() + Controller1.Axis1.value()), vex::velocityUnits::pct);
BackLeft.spin(vex::directionType::fwd, (Controller1.Axis3.value() + Controller1.Axis1.value()), vex::velocityUnits::pct);
FrontRight.spin(vex::directionType::fwd, (Controller1.Axis3.value() - Controller1.Axis1.value()), vex::velocityUnits::pct);
BackRight.spin(vex::directionType::fwd, (Controller1.Axis3.value() - Controller1.Axis1.value()), vex::velocityUnits::pct);
Brain.Screen.clearScreen();
Brain.Screen.setCursor(1,0);
Brain.Screen.print(Arm.position(degrees));
if(Controller1.ButtonL1.pressing()){
Arm.setVelocity(50, percent);
Arm.spinToPosition(271.20, degrees);
else if(Controller1.ButtonL2.pressing()){
Arm.spin(forward, 100, percent);
else {
Arm.stop();
