Ive been told by my mentor teams that motors will ideally want to run under 1 watt, but why is that? I know that it is good I just want to understand why it is so i can document it in the nb and such.
I suspect what they are discussing is the power consumed by the motor when the mechanism is unloaded. This is a good indication of losses in your system (primarily friction).
A couple of key points to be aware of:
- The mechanism is unloaded
- Drivetrain wheels are not touching the ground
- A conveyor belt is not carrying any game objects
- An arm is not lifting anything beyond itself
- The power reported is how much power is ‘lost’ in the mechanism
- This power is not available for doing ‘useful’ work
- Higher losses also lead to motors overheating more quickly
- The primary culprit in this measurement is friction
- A number of design and build issues can make this much worse
- Bent shafts
- Crooked shafts (bearings offset from one another)
- Misaligned bearings (3 or more bearings that are not perfectly aligned)
- Excessive side loads (shafts being forced sideways in the bearings)
- Shafts with very high side loads (like pivots on a large lift) can benefit from ball bearings
- Slop in the structure (does it bend when you push on it?)
- Unsupported gears
- Gears try to push away from each other under load
- If this is not well restrained you can end up with bearing friction and skipping gear teeth
This is not a comprehensive list, but hopefully it is a starting point.
That would be a great lesson for your teacher to explain. They could roll into it when to pick the 5w or the 11w motors.
