I tried to program an auton to get the hang of programming, however my code will not run. It says I have downloaded the code and does not give any errors but none of the commands will run. My teammates code will run and that code is on a different laptop. Does anyone have any solutions?
What editor are you using to program your robot? Below is an example in VexCode. Pros may be a little different but follows the same conventions.
Does the program know that you want to use my_first_auton()
as the autonomous program? This requires you to also bind to it in the main()
function.
For example, using the V5 template in VexCode, I created a custom auton function.
Note the comments in the code.
// Include the V5 Library
#include "vex.h"
// Allows for easier use of the VEX Library
using namespace vex;
// Begin project code
void preAutonomous(void) {
// actions to do when the program starts
Brain.Screen.clearScreen();
Brain.Screen.print("pre auton code");
wait(1, seconds);
/// <<< ----Modified Code---- >>>
// I created my special Auton function here, and
// I have to bind it below to a competition callback.
void MySpecialAutonomous(void) {
Brain.Screen.print("autonomous code");
void userControl(void) {
// place driver control in this while loop
while (true) {
wait(20, msec);
int main() {
vexcodeInit();
// create competition instance
competition Competition;
// Set up callbacks for autonomous and driver control periods.
// Here I'm telling the Competition system that
// MySpecialAutonomous function is the autonomous code to use.
Competition.autonomous(MySpecialAutonomous);
Competition.drivercontrol(userControl);
// Run the pre-autonomous function.
preAutonomous();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
