We are a new Vex robotics Starstruck team and we wonder can we wield parts together for the robots
No, assuming you mean weld.
<R15> Parts may NOT be modified as follows:
b. Welding, soldering, brazing, gluing, or attaching in any way that is not provided within the VEX
Robotics Design System will NOT be allowed.
Please thoroughly read the VEX Starstruck Game Manual before posting questions about it on the Forums.
Also, post such questions in the Official Starstruck Q & A channel, not the Technical Support channel.
I would also like to add, since you are a new team, that there really is no need for welding anyways. There are plenty of methods of coupling parts with out them. For example, if you need to join 2 c channels together, you can simply use a small piece between them and screw both of them in. Or, if your feeling sophisticated enough, Vex specifically sells some gussets that you can use to couple things. If you have any questions about specific things that you need to couple, feel free to ask.
