I’m sure we’ve all had connectors or pins break on wires, and it’s unfortunate to lose a motor or sensor for such a small thing.
Robosource.net now offers all the parts and tools you need to fix VEX cables and connectors starting at $0.30: Premium Rubber Bands, Size 64, 100 pack - Robosource.net You could also make your own wires, which would have to be identical length to the VEX ones if you’re using them for a competition robot, or if you’re not competing you could even make your own custom length wires.
https://www.robosource.net/460-large_default/3-male-kit.jpg
Repairs to wires are VRC legal by rule R15a (see this clarification for additional details). Please note that the keyed connectors on VEX wires seem to be custom made, and can’t be found anywhere else. Therefore, should you want to keep the keyed connector, you will have to carefully remove and reuse the one that was previously on the wire. However, non-keyed connectors are also legal.
Crimping pins isn’t too hard once you get the hang of it. We are going to release detailed information including photos and a video on the repair process soon.
A note about crimping tools: The crimping tool we offer is $24.99, which is a bit more than what we’d usually aim for pricing wise at Robosource.net. You can find other crimpers online and we’ve tried a lot of different ones, however if you’re not paying $20-$30+ chances are it’s best not to buy it. Most crimpers will deform the pins and make them hard or impossible to insert into the housing, including a very similar looking one that is quite common and often labelled SN-28B. That one has 3 crimping slots that won’t work well, while the correct sized tools generally have 2 slots, with the smaller slot being the correct one. If you’re just fixing a few wires and don’t want to buy a tool, it is also possible to use some pliers, but it is a bit trickier to get the crimp right.
