WOuld mu USer code and AUton work if I put it this way in the Competition template?
#include “robot-config.h”
Description: Competition template for VCS VEX V5 /
//Creates a competition object that allows access to Competition methods.
vex::competition Competition;
/* Pre-Autonomous Functions /
You may want to perform some actions before the competition starts. /
Do them in the following function. You must return from this function /
or the autonomous and usercontrol tasks will not be started. This /
function is only called once after the cortex has been powered on and /
not every time that the robot is disabled. /
void pre_auton( void ) {
// Example: clearing encoders, setting servo positions, …
Autonomous Task /
This task is used to control your robot during the autonomous phase of /
a VEX Competition. /
You must modify the code to add your own robot specific commands here. /
void autonomous( void ) {
while(Sonar1.distance(distanceUnits::in) <8)
Arm1.spin(vex::directionType::fwd,200, vex::velocityUnits::pct);
while(Sonar1.distance(distanceUnits::in)>8)
Frontleftmotor.spin(Vex::directionType::fwd,200,vex::velocityUnits::pct);
Backleftmotor.spin(vex::directionType::fwd,200, vex::velocityUnits::pct);
Backrightmotor.spin(vex::directionType::fwd,200, vex::velocityUnits::pct);
Frontrightmotor.spin(vex::directionType::fwd,200, vex::velocityUnits::pct);
Frontleftmotor.stop();
Frontrightmotor.stop();
Backleftmotor.stop();
Backrightmotor.stop();
User Control Task /
This task is used to control your robot during the user control phase of /
void usercontrol( void )
Backleftmotor.spin(vex::directionType::fwd, Controller1.Axis3.value(), vex::velocityUnits::pct); //(Axis3+Axis4)/2
Backrightmotor.spin(vex::directionType::fwd, Controller1.Axis2.value(), vex::velocityUnits::pct);//(Axis1-Axis2)/2
Frontleftmotor.spin(vex::directionType::fwd, Controller1.Axis3.value(), vex::velocityUnits::pct); //(Axis2+Axis1)/2
Frontrightmotor.spin(vex::directionType::fwd, Controller1.Axis2.value(), vex::velocityUnits::pct); //(Axis4+Axis3)/2
if (Controller1.ButtonUp.pressing())
else if (Controller1.ButtonDown.pressing())
Arm1.spin(vex::directionType::rev, 200, vex::velocityUnits::pct);
else if (!Controller1.ButtonUp.pressing())
Arm1.stop();
       else if (!Controller1.ButtonDown.pressing())
           Arm1.stop();
while (1){
vex::task::sleep(20); //Sleep the task for a short amount of time to prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
//Run the pre-autonomous function.
pre_auton();
//Set up callbacks for autonomous and driver control periods.
Competition.autonomous( autonomous );
Competition.drivercontrol( usercontrol );
//Prevent main from exiting with an infinite loop.
while(1) {using namespace vex;
while(true)
  vex::task::sleep(100);//Sleep the task for a short amount of time to prevent wasted resources.
It says there is an error at the Void usercontrol part
Now there is also a Error where it says Drive control USer control.
