I did this purely for the fun of it.
https://vexforum.com/attachment.php?attachmentid=5353&stc=1&d=1329950702
Yes, it actually works and compiles and runs, etc. See attachments below.
EnglishC.zip (48.7 KB)
That’s really cool. I remember that I wrote a javascript script to do this with ROBOTC a while back. No one really found it too helpful though. Do you find that people like using this type of interface?
I haven’t tried to get anyone to use it. I’ve showed it to some of my teams and they think it’s amazingly easy, but I still prefer using functions than typing text. I guess the easy part about it to them is being able to understand it without any unfamiliar symbols or understanding C in general.
Sorry I do not have easyc capabilities this moment. How did you get that to work? Did you have to do a ton of other or stuff or did you literally just drag in C code blocks and write stuff in?
// UserInclude.h : header file
#ifndef USERINCLUDE_H_
#define USERINCLUDE_H_
typedef void (*ActionFunc)(double SpeedPercent);
typedef struct Event_t
unsigned long when;
ActionFunc ToDo;
double Param;
struct Event_t *next;
} Event;
extern Event *event;
void add_event(double Time, ActionFunc Action, double SpeedPercent);
#define At add_event(
#define seconds
#define move ,
#define make ,
#define up , +
#define down , -
#define forward , +
#define backward , -
#define left , -
#define right , +
#define with
#define percent
#define speed );
#define stop , 0);
//At <Time> seconds move <ActionFunc> <up/down/etc...> with <SpeedPercent> percent speed
//At <Time> seconds make <ActionFunc> stop
void Execute(void);
#define End Execute();
#endif // USERINCLUDE_H_
// UserSource.c : implementation file
#include "Main.h"
#include "stdlib.h"
Event *event = 0;
if(!event)
event = (Event*)malloc(sizeof(Event));
event->when = Time*1000;
event->ToDo = Action;
event->Param = SpeedPercent;
event->next = 0;
return;
Event *evt = event;
while(evt->next) evt = evt->next;
evt->next = (Event*)malloc(sizeof(Event));
evt->next->when = Time*1000;
evt->next->ToDo = Action;
evt->next->Param = SpeedPercent;
evt->next->next = 0;
void Execute(void)
Event *evt = event;
unsigned long time = 0;
while(evt)
Wait(evt->when - time);
time = evt->when;
evt->ToDo(evt->Param);
evt = evt->next;
if(!event) return;
evt = event;
while(evt->next)
Event *t = evt;
evt = evt->next;
free(t);
event = 0;
There may or may not be issues. I certainly could have done this entirely differently without the need for the crazy structure I am using.
That is very very clever! Good job on making that!
Next, if you want even more functionality, you can add commands like until, and sensor input. Basically to make it more natural language-like. So users can type in, “go forward until sensor 3 is hit. Then turn left and wait for 300 milliseconds.” It sounds hard, but it’s not terribly difficult, just tedious. (I’m not sure about EasyC, because, as I said, I did this in javascript). You might also want to check out ROBOTC’s “Natural Language” interface.
I think at that point I am better off making it take it as a string literal and parse it than trying to use my current system of #defines to make a function call.
This is a very innovative interface you’ve created. If your only team members that are well-versed in the code are sick on the day of a tournament, then the others can still program the robot if they need to. Kudos!
