X Drive Autonomous
Wondering how to do autonomous for a x drive with four motors. My main goal for autonomous is to stack the pre load in the beginning of the match to one of the mobile goals and bring it back to the 10 or 20 point goal. Here is a my driver control code bellow if that helps
 #pragma config(Sensor, in1,    Pot,            sensorPotentiometer)
#pragma config(Motor,  port1,           Claw,          tmotorVex393_HBridge, openLoop)
#pragma config(Motor,  port2,           fourLeft,      tmotorVex393_MC29, openLoop, driveRight)
#pragma config(Motor,  port3,           fourRight,     tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port4,           sixLeft,       tmotorVex393_MC29, openLoop, driveRight)
#pragma config(Motor,  port5,           sixRight,      tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port6,           FL,            tmotorVex393_MC29, openLoop, driveLeft)
#pragma config(Motor,  port7,           FR,            tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port8,           BR,            tmotorVex393_MC29, openLoop, driveLeft)
#pragma config(Motor,  port9,           BL,            tmotorVex393_MC29, openLoop)
#pragma config(Motor,  port10,          Goal,          tmotorVex393_HBridge, openLoop)
//  ROBOT SEEN FROM ABOVE
//        X FRONT X
//      X           X
//    X  FL       FR  X
//            X
//           XXX
//            X
//    X  BL       BR  X
//      X           X
//        X       X
// Controller 1/2, Stick L/R, Axis X/Y
#define C1LX vexRT[Ch4]
#define C1LY vexRT[Ch3]
#define C1RX vexRT[Ch1]
task main() {
	while(true) {
		// Y component, X component, Rotation
		motor[FL] = -C1LY - C1LX - C1RX;
		motor[FR] =  C1LY - C1LX - C1RX;
		motor[BR] =  C1LY + C1LX - C1RX;
		motor[BL] = -C1LY + C1LX - C1RX;
		// Motor values can only be updated every 20ms
		wait10Msec(2);
		while(true)
			if (vexRT[Btn6U] == 1)
			motor[fourLeft] = 127;
			motor[fourRight] = 127;
			motor[sixLeft] = 127;
			motor[sixRight] = 127;
		else if (vexRT[Btn6D] == 1)
			motor[fourLeft] = -127;
			motor[fourRight] = -127;
			motor[sixLeft] = -127;
			motor[sixRight] = -127;
		else
			motor[fourLeft] = 0;
			motor[fourRight] = 0;
			motor[sixLeft] = 0;
			motor[sixRight] = 0;
	if(vexRT[Btn7U] == 1) //If the button is pressed... LIFTS UP
		if(SensorValue[Pot] < 900) //If the Potentiometer
		{ //has not reached its maximum point...
			motor[fourLeft] = 69; //turn the motor on forward.
			motor[fourRight] = 69;
			motor[sixLeft] = 69;
			motor[sixRight] = 69;
		else //If the Potentiometer has reached
			//its maximum point...
			motor[fourLeft] = 0; //turn the motor off.
			motor[sixLeft] = 0;
		if(vexRT[Btn7D] == 1) //If the button is pressed... LIFTS DOWN
			if(SensorValue[Pot] > 100) //If the Potentiometer
				//has not reached its minimum point...	///////////////////////////////////////////
				motor[fourLeft] = -31; //turn the motor on in reverse. ////////Remember to check this ///////////
				motor[fourRight] = -31;
				motor[sixRight] = -31;
				motor[sixLeft] = -31;	/////////////////////////////////////////
			{ //its minimum point..
				motor[sixLeft] = 0;
				if (vexRT[Btn8U] == 1)
					motor[BR] = 127;
					motor[BL] = 127;
					wait(2000);
					motor[port2] = 50;
					motor[port3] = 50;
					motor[port4] = 50;
					motor[port5] = 50;
					motor[port6] = 50;
					wait(1000);
					motor[BL] = 127;
					motor[BR] = 127;
Well, first of all, you’ll want some sensors on your drivetrain. Shaft encoders are generally the best choice.
Yah, forgot to say that i have 2 on the robot do i need 4 or 2 would work
2 works if you don’t plan on strafing in auton. If you plan on fully uitlizing the x-drive’s capabilities than it will require 4 (you might be able to get away with 3 also but that would be very OCD invoking) .
Ok, yah probably want to use all the capabilities of the x drive but now my question how to code it I don’t know how to code autonomous for x drive
Think of your axis offset 45 degrees and code up each nw/se & ne/sw pairs as your new x & y axis. So get the ticks per inch or centimeter you want to travel, and use those in your PID. Have one PID for NW/SE and one for NE/SW axis. It will hone in on the one direction sooner and follow a straight line for the remaining axis.
if you want better path planning, that is a whole other ball of wax.
