1" Wedgetop Tread as thank-tread
I bought 1" Wide Wedgetop Tread and a 4" Traction Wheel included traction tire. Im looking for some advice on how i could mount this and get the 4" Traction Wheel to drive the Wide Wedgetop Tread around like a conveyor belt. As I see it now the treads will only slip on the wheels.
I want this setup to run my robot as a tank. The goal is to use this system to drive a robot forward using the tread belts with high friction to the ground.
Do you have any suggestions or recommended methods to make this work effectively with theese parts? Or do I need some other parts for this?
