4 motor Drivetrain
Hi so we’re a new rookie team and I was just wondering what is the best drivetrain for 4 motors? Our team currently to all the gears except for those like 48 tooth gears or 24 tooth metal gears. I’m just wondering if a 1:6 gear ratio good for drive? If not, what’s the best drive train that balances out speed and torque with only using 4 motors. Once again, we are a new team so we don’t really know how to work with 2 left over motors and pneumatics.
Great post, I would give it a read.
Anyways, shoot for a speed around 50-55 in/sec. You’ll be slow, and yu’ll be pushed around a bit, but you’ll be competitive.
I highly recommend doing a 6 motor drive. Unless you’re shooting for a high skills score (in that case make your robot faster), you can have a 6 motor drive, 11w intake, and an 11w flywheel. Or you can do a 77w drive and an 11w intake and make a de-scoring bot like hailstorm (first year I’ve seen a really successful 8 motor pushbot)
I woulf recommend getting your feet wet by building some vertical wings.
use blue motors and run a 360rpm ratio(36:60) on 3.25 omni wheels, its a fast, strong, and very competitive ratio and you are still able to use your other motors for a 1m flywheel and 1m intake with whatever wings/ hang you choose
From a seventh-grade team who has used both 4-motor and 6-motor drive this season, I truly recommend the 6-motor drive. A 5:3 ratio gives you 360 rpm, which gives good speed, torque, and leaves motors for an intake, flywheel/kicker, or even motorized wings if you want those. Our 4-motor drive bot currently has a 3:5 ratio, and that gets 300 rpm, but that’s with green motors and is kinda slow. Go with a 6 blue motor, 5:3 ratio on 3.25 inch wheels.
sorry to stomp on the points you made but they stated they only had 6m total, and you do not need the 6 motors on a 360rpm drive, as it should run fine with 4 motors, we average around 14 minutes of driving before I notice any difference in torque, and it usually correlates to our battery charge, and we run 4 motors on a 14-pound robot
It’s not really fast tho :person_shrugging: We run 450 2.75 and as the driver, I honestly think it is still really slow and I’m aiming that we bump it up to 480 3.25.
Thank you so much. Im actually just looking for advice for next season because states already ended here in Hawaii
