7/10 meta bot, or 10/10 kit bot?
Now with the kit bot, it can now pick up the pins and cones and make a 4 stack with it. No toggle control and can pick up match load.
Meta bot has an intake that jams after 5 cones and 6 pins. The cascade can come apart very easily and the drive motors are green or red. And the auton will not work half the time.
So, if you had to pick one, which one will you choose?
Toggles are so very important, so because the kit bot can’t change the toggles I would choose the 7/10 Meta bot. But it’s up to your team I would do some testing to see which bot performs better. I would also try to turn the 7/10 meta bot into more of a 8 or 9 out of 10.
Probably the meta bot.
You can switch out the motors for blue cartridges. The intake can be fixed, and you can also rebuild the cascade, or use a dr4b (or dr6b) instead. The toggles are really important as well. And the auton will probably work better if you make the robot more consistant, or just fix the auton.
So yeah, I would recommend the metal if your team is good at building and has time for it. But if you can’t just build the kit bot, and add a mech for toggles.(Although I haven’t looked at what that robot is like, and how many motors it already used.).
This question is just for the love of the game. I do not have anything from the kit or meta bot. All that I am doing is a x drive with a Dr4b.
Ooo, alr.
Im also doing X-drive. (But with a cascade).
We might switch to dr4b or dr6b later in the season, if cascade becomes to complicated.
