The 2 motors are located just above the back wheel, which is chained to the 4 bar
I’ve been looking 8059a for a while now, and I’ve noticed that the back wheels have 4 motors on each of them. Where are the 2 remaining motors you claim to be on the chassis?
It started off with 10 motors.
But during the 1st day of competition, one of the junior teams had some of the ports on their cortex fried.
8059a swapped their cortex with the junior team.
And they needed to remove two motors from the drive because of that.
So you are right - currently there are only 8 motors for the drive. But you can easily put 2 more motors back in.
And btw, questions related to 8059a will take a longer time for us to get back to you - the original team of 8059a has retired, and busy preparing for their IBDP exam.
So yes… the team that brought you single flywheel and the only 4-ball catapult (in worlds) and the concept of Ri1D has retired ![]()
@meng Sad to hear of the retirement. We have shut down 6430, 6430B and 6430V. Just doing 1 MS IQ team this year, 6430X. It was great getting a chance to play with you guys and getting to know you. Best of luck this year!
Oh… 6430 has graduated too? That’s sad to hear. But it is great to see how 6430 has improved over the years ![]()
Hope we will get to alliance with each other again in HS worlds… soon ![]()
How were you able to stabilize the lift? Is it just a matter of getting the right tension for the latex on the side? Also, is there a method to figuring out the right tension on each side or is it just trial and error?
Hi,
Regarding 59z, the stability of the lift is not only entirely dependent on the latex on each side. Although an equally tensioned latex system is a precondition to a stable lift, a lift can still wobble/sway to considerable degrees.
It isn’t easy to give one magic solution, but making sure all joints are equally tightened and an overall good build quality are imperative.
If you were to look at 1.12 of the reveal video, you would be able to see a very thick piece connecting the upper section of the rd4b. It’s what we call a magic bar- two c channels screwed together to virtually eliminate twist. This does help with the stability of the lifts also.
Perhaps this thread may also be useful:
Thanks.
Your reveil was awesome, but we would like to know if you have a cad or blueprint of your design. If so, would you be willing to share it with us. Any help would be great.
Hi… thanks for your kind words.
We usually don’t do cad. The short prep time we have for singvex usually means it has to be fast prototyping, and no time for cad.
But is there any specific area that you want to find out more?
How bout a reveal for the rest of the 8059 teams like the tournament champions of the competition posted on YouTube? These bots are fantastic and I’m sure that the rest of 8059 are as well.
Our singvex 8059f is currently partially cannibalizes.
We will see how we can do a simple reveal for that.
It eats other robots?
Sigh… stupid autocorrect… it is supposed to be past tense - cannibalized.
Lol
So we’re safe from a carnivorous robot.
For now
@meng how did you guys use stabilize both sides of the chain bar using only 1 motor? How did one side not go up faster than the other?
Hi @kush_shah_7405N ,
To reduce bending, an axle runs through both sides of the chain bar at the gearbox. This syncs the movement of the gears on the chain bar.
For the mobile goal intake, do you think a design with pneumatics would be more battery efficient and faster, or would you keep the mobile goal design like that?
You can use pneumatic for the mobile goals. It will definitely be faster than the motors.
If you are referring to 8059Z mobile goal intake - then no… we had already moved on from that intake design (3 days after it was built).
In terms of mobile goal intake, 8059D was our ver 1.0; 8059Z was ver 1.1. And shortly after, 8059F was ver 2.0 (you can catch a glimpse of it in the videos of the singvex final matches).
Alright. And thank you for letting a CAD model of 8059Z made, my school is new to vex competitions and this will get our foot in the door.
