VEXcode Pro auto re-compiling .cpp/.c source file when included header .h files(#include"xxx.h") is modified, by adding some code to makefile rules。
My code structure is as follows:
All the functional modules are in a folder and placed under /src folder. Each functional module basically contains an .h file and some .cpp files
When you modify any of your header files, all source files that reference the header file are automatically recompiled
so that the changes to the header file take effect.
Implementation Mode:
(1) replace you_project_folder/src/vex/mkrules.mk with this
mkrules.mk.zip (4.3 KB)
(modified mkrules.mk and a text is inside)
(2) add some makefile rules to the file: you_project_folder/src/vex/mkrules.mk by yourself
code below:
Note: make sure when you copy the code to your mkrules.mk, the tab character before $(conditional_generate_dependency_files) would not be changed into white spaces by VEXcode。
so the easierway is (1)。
###### 使用方法: 复制下面所有代码(或者本文所有内容), 通过“记事本”或者vexcode打开:你的程序项目/vex/mkrules.mk,并将代码粘贴到mkrules.mk最后面
###### instructions: copy all the code below(or the whole text of this text file), with "notepad.exe" or vexcode, open the file: your-project-folder/vex/mkrules.mk, then paste the code to the end of mkrules.mk
### 生成自动依赖关系的文件,当头文件修改时,可以自动重新编译关联的cpp和c文件
### Generates an automatic dependency .d file,
### which automatically recompiles the associated .cpp and .c file when the header .h file is modified!
### 以下是windows CMD代, linux 好像不一样
### the code works in windows CMD, maybe not in linux
### 命令包1: 生成 .d 文件的命令包,供cpp和c文件使用。如果头文件不存在,则只会生成空文件
### command pack 1: generate .d file for compinling c\cpp files
define gen_dep_with_headers_check_except_trailing_space
$(Q)$(MKDIR)
@$(ECHO) -------------making dependency file^: $@ , added by LQ from VEX team 74000
@$(CXX) $(INC) -MM -MT "$@ $(subst .d,.o,$@)" $< >$@ 2>nul
endef
### 命令包2: 判断vexcode要做的事情:清除 或者 编译
### 如果传递的指令是clean等,则不执行;编译时,MAKECMDGOALS为空,则执行gen_dep来生成d文件
### command pack 2: if make clean, it's not going to generate .d files;
### if compiling project(only "make" called,thus $(MAKECMDGOALS) is empty), $(gen_dep) will run to generate .d files
define conditional_generate_dependency_files
$(if $(MAKECMDGOALS), , $(gen_dep_with_headers_check_except_trailing_space))
endef
### c\cpp文件的d文件静态生成模式
### Static Pattern Rule for .d file from cpp and c file
$(BUILD)/%.d: %.cpp $(SRC_H) $(SRC_A)
$(BUILD)/%.d: %.c $(SRC_H) $(SRC_A)
### 引入所有的.d依赖文件
### include all .d files for auto recompiling
-include $(OBJ:.o=.d)
###### 注意 1:粘贴后,如果指令($(conditional_generate_dependency_files) )前的tab不小心被vexcode替换成了两个空格,则会出现类似报错:vex/mkrules.mk:64: *** multiple target patterns. Stop.
###### 解决办法:重新粘贴,不要在vexcode中编辑。
###### Note 1: After pasting, if the tab in front of the command($(conditional_generate_dependency_files) ) is replaced by Vexcode with two spaces, a similar error occurs: Vex mkrules.mk : 64: * * * multiple target patterns. Stop.
###### Solution: just re-paste, save , and do not edit mkrules.mk in vexcode
###### 注意 2:在cpp/c 的源代码中,#include指令的<> 或者"" 中的头文件名字后面,不要加入空格,例如:#include "my_header.h "。否则d文件能成功生成,但是会报错。
###### 解决办法:删除头文件名后的多余空格,然后关闭vexcode,重新双击你的项目文件(xxx.v5code),软件就会自动清除编译的缓存; 或者你自己手动删除项目文件夹中的build文件夹。
###### Note 2: in the CPP/C source code, do not add spaces after the name of the header file in the #include directive, for example: # include "my_header.h ". Otherwise, the .d file can be generated successfully,
###### but an error will be reported.
###### Solution: remove the extra space after the header file name, close vexcode, and double-click Your Project File (xxx.v5code) , the software automatically clears the compiled cache; or you can manually delete the build folder from the project folder.
PS: I am using Windows, the code need to be modified for linux。
