Abbreviations in Forums
I am new to the VEX forums and I appreciate all of the great posts and ideas everyone is putting up here. I am creating this post for all the other newbies out there like me who see all sorts of abbreviations and don’t really know what they mean.
For example I see DR4B and I know it is some kind of lift, and I have seen lots of pictures of various lifts, but I don’t know exactly what it stands for. So hit me with all of your commonly used VEX abbreviations.
DR4B = double reverse 4 bar linkage
TP = Turning Point
TT = Tower Takeover
BO3 = Best of 3
BO1 = crap
Dr6b-double reverse six bar
Dr8b-double reverse eight bar
VCS-Vex coding studio
Nbn-nothing but net
Ss-starstruck
Itz-in the zone
Tt-Tower takeover
Bo1-technically means best of one, I suggest not looking at the debates over bo1 and bo3
Ep-event partner
Tm-tournament manager
Good luck😀
I know we switched to BO1 last season. Is that still the rule for this season? (not arguing the merits of either, just want to know the current rule).
As of now, yes.
RCEF could still potentially change it for State or Worlds, but that’s a longshot.
The rules for a tournament are found in the game manual (around page 35 of the pdf, linked here for your convenience): https://link.vex.com/docs/vrc-tower-takeover/TowerTakeover-GameManual
Specifically, the “BO1” rule is T13
Those drawings are incorrect. The one you have labeled “6 bar” is actually a type of 8 bar linkage, and the one you have labeled “5 bar” is a standard 6 bar.
Edit: Also the “1 bar” is more formally known as a 2 bar.
I know what he has labeled as an “6 bar” is technically an 8 bar linkage but I think that “double 4 bar” is a bit more informative since an “8 bar” is usually referring to his “5-bar” but with another stage. Just like you wouldn’t call a mechanically linked “dr4b” an “8 bar”.
While I realize that these abbreviations and names are ubiquitous in the VEX community, I hope everyone realizes that outside of competitive robotics, these “linkage names” are not common or standard industry (or mechanical engineering) names. Even the most common mechanism, the “4-bar” is actually an entirely different type of mechanism to most any non-vex-knowledgeable-mechanical engineer: Four-bar linkage - Wikipedia
(and we won’t even get started as to who Danny or Goliath are!):slightly_smiling_face:
Very true. I have tried to get some of our teams to absorb actual 4 Bar Linkage design for a few different things in the past, but none have really wanted to deal with that.
Most people know it by PROS, but it stands for Purdue Robotics Operating System. It is another coding platform for VEX.
https://pros.cs.purdue.edu
Actually, that is no longer true. PROS quietly had a name change:
If you feel like it, you could get away with calling it BROS or any other letter due to the nature of recursive acronyms :wink:
I stand corrected! I had no idea that happened. My bad.
Yup… you are right. That was not a 6-bar.
Anyway, for those who are wondering how do you “name” or “number” the bar linkage, you can take a look at this document:
In summary, the number of bar is not based on the number of c-channels, it is based on the number of nodes or joints.
This summary is confusing to me… strictly speaking, wouldn’t this definition mean that a standard 6 bar should be called a 7 bar? It has 7 nodes/joints
Some people also refer to them by how many parallel bars there are in one direction or another. Or just by orders of complexity. There is not a real rule. These do not come from industry norm or international standard, just common usage among teenagers.
Same goes for drive systems.
X-Drive (four omni wheels on corners at angles)
H-Drive (four omni wheels in standard config, with a fifth perpendicular in the middle)
Also, sometimes a specific drive will be called a Holonomic drive. This does not refer to any particular configuration of wheels, as both of the above as well as Mecanum drives are all Holonomic. Holonomic vs Non-Holonomic is just whether or not it can control all available degrees of freedom. Drive, Strafe, Rotate in place.
Also, Kiwi Drive (three omni wheels in a triangle)
Bling drive: A style of building a 6-wheel chassis where two of the omni-wheels are “locked”, or have screws shoved between the rubber rollers and the plastic wheel frame.
Think you are referring to that point in the middle of the centre, Long c-channel?
That point is not considered a node.
An easier and simpler definition of a node or joint is a point that joins up different linkages and there is movement,
So technically, that point in the centre of the Long c-channel is on the same linkage.
It is definitely confusing. And another thing to note is that the n-bar linkage in VRC is not the same as the conventional n-bar in industry. So this adds on to the confusion.
