AI vision sensor detecting mobile goals intermittently
I have been testing the AI vision sensor to detect game objects like the red and blue ring and mobile goal. It detects them all decently, but often flickers on and off between snapshots as to whether it can actually see mobile goals. Is there any way to raise sensitivity so it detects them better?
Also the wifi enabled and visualise on a phone doesnt seem to work, the wifi network for the sensor doesnt show up even when the settings is enabled
The aivision sensor does not include wifi, you are using this one ?
Yes im using this one. I think the setting for wifi is in the menu no matter what but is only for the normal vision sensor, my bad.
Also now the ai vision sensor just isnt detecting anything, ill try redoing what model it uses in vexcode and try again
I have now redownloaded the model and it detects red and blue rings, but not mobile goals
When you download the model to the sensor in vexcode, are you doing it with classroom objects or competition object selected?
Classroom has red and blue rings, but nothing yellow so it will struggle with the mobile goal. Competition objects won’t have the same generic things as classroom objects will, but it in my experience works quite well for mobile goals, as it is trained to do that.
TL;DR: make sure you’re using the competition objects model.
Ah! That was the problem! Thank you
