Ai_vision_sensor not connecting to vexcode
Hello. I am attempting to connect the ai_vision_sensor to Vexcode. I am a Vex v5 user. Unfortunately, it is not working. The computer that I am currently using is a Mac Mini. Here is a hardware overview of my computer, generated by the system_profiler SPHardwareDataType command:
Hardware Overview:
  Model Name: Mac mini
  Model Identifier: Mac16,10
  Model Number: Z1CG00018LL/A
  Chip: Apple M4
  Total Number of Cores: 10 (4 performance and 6 efficiency)
  Memory: 24 GB
  System Firmware Version: mBoot-18000.161.9
  OS Loader Version: 11881.140.96.701.1
  Serial Number (system): QQW3HC6FR2
  Hardware UUID: 5CD4F044-F606-5B8B-BB5F-F73076BDC468
  Provisioning UDID: 00008132-001E09E00153801C
  Activation Lock Status: Disabled
When I run the system_profiler SPUSBDataType command, the computer clearly recognizes the camera as connected. Here is the output regarding the camera, that comes from running that command:
GPS Sensor:
          Product ID: 0x0521
          Vendor ID: 0x2888
          Version: 1.01
          Speed: Up to 480 Mb/s
          Manufacturer: Vex Robotics, Inc
          Location ID: 0x02120000 / 4
          Current Available (mA): 500
          Current Required (mA): 100
          Extra Operating Current (mA): 0
Interestingly, it seems to categorize it as a GPS sensor for some reason. When I log onto vexcode, I press “add device”, followed by “configure”, followed by “connect”. When I press connect, it displays a message that says, “no compatible devices found”. Changing code.vex.com’s permissions on the browser does not help. How can I fix this? Thank you in advance.
That is the USB product ID for a GPS sensor. Does your “ai vision” sensor have "AI " silk screened on the side ?
You can stream both the GPS and the AI vision sensors in Quicktime Player, perhaps open that and see if it streams a monochrome (GPS) or color image.
Somebody on my team gave me a GPS sensor but told me that it was an AI sensor. Sorry. Apologies for wasting your time. I really should have looked at the side.
