Am I doing the math right (Repost)
Sorry i put the wrong code from my last topic post. I am Doing Odomitry for the first time and am using the Inertial and two dead wheels and a little bit of the powered ones and am wondering if i did the math right
from vex import *
import math
class odometry:
def \__init_\_(self):
    self.leftEncodedMotor: Motor
    self.rightEncodedMotor: Motor
    self.XPosition: float = 0.0
    self.YPosition: float = 0.0
    self.Inertial: Inertial
    self.InertialSensorUse=False
    self.XSpeedLocalI: float = 0.0
    self.YSpeedLocalI: float = 0.0
    self.LDistanceM: float = 0.0
    self.RDistanceM: float = 0.0
    self.XDistanceI: float = 0.0
    self.YDistanceI: float = 0.0
    self.RobotWidthMM: float = 0.0
    self.WheelDiameterMM: float = 0.0
    self.DistanceGlobalM: float = 0.0
    self.Timer=Timer()
    self.ODT: Thread
    self.Xodom: Rotation
    self.Yodom: Rotation
    self.OdomWheelDiameter_MM: float = 0.0
    self.XOdomOffset: float = 0.0
    self.YOdomOffset: float = 0.0
    self.Weight: float = 0.98
    self.GearRatio: float = 0.0
    self.InertialXOffset: float = 0.0
    self.InertialYOffset: float = 0.0
    self.InertialZOffset: float = 0.0
    self.XgravityOffsetDegrees: float = 0.0
    self.YgravityOffsetDegrees: float = 0.0
    self.ZgravityOffsetDegrees: float = 0.0
    self.TimeStep_Sec: float = 0.01
@staticmethod
def calabrate_inertial():
    OD.Inertial.calibrate()
    RollA=math.degrees(math.atan(OD.Inertial.acceleration(AxisType.YAXIS)/OD.Inertial.acceleration(AxisType.ZAXIS)))
    OD.XgravityOffsetDegrees=RollA
    PitchA=math.degrees(math.asin(OD.Inertial.acceleration(AxisType.XAXIS)/9.81))
    OD.YgravityOffsetDegrees=PitchA
@staticmethod
def \_Run() -> None:
    OD.XSpeedLocalI=(round(OD.Inertial.acceleration(AxisType.XAXIS), 3)\*(0.01\*\*2))
    OD.YSpeedLocalI=(round(OD.Inertial.acceleration(AxisType.YAXIS), 3)\*(0.01\*\*2))
    LeftDegOld=OD.leftEncodedMotor.position()
    RightDegOld=OD.rightEncodedMotor.position()
    FilteredRoll_Rad: float=0.0
    FilteredPitch_Rad: float=0.0
    FilteredYaw_Rad: float=0.0
    AxisWeight: float=0.9
    DistancePerDegree_Mpd: float=(math.pi\*(OD.WheelDiameterMM/1000))/360
    TotalGravity=9.81
    while True:
        StartTime=OD.Timer.time()
        \# Cleaining acceleration data.
        LeftSpeed_Mps=((OD.leftEncodedMotor.velocity(RPM)/OD.GearRatio) \* DistancePerDegree_Mpd) / 60
        RightSpeed_Mps=((OD.rightEncodedMotor.velocity(RPM)/OD.GearRatio) \* DistancePerDegree_Mpd) / 60
        HeadingRate_Mps=math.degrees(((RightSpeed_Mps-LeftSpeed_Mps))/(OD.RobotWidthMM/1000))
        ZAxis_G=OD.Inertial.acceleration(AxisType.ZAXIS)
        XAxis_G=OD.Inertial.acceleration(AxisType.XAXIS)
        YAxis_G=OD.Inertial.acceleration(AxisType.YAXIS)
        XAxisForGravity_G=OD.Inertial.acceleration(AxisType.XAXIS) - (OD.Xodom.velocity(RPM) \* OD.OdomWheelDiameter_MM \* math.pi / 60)/OD.TimeStep_Sec
        YAxisForGravity_G=OD.Inertial.acceleration(AxisType.YAXIS) - (OD.Yodom.velocity(RPM) \* OD.OdomWheelDiameter_MM \* math.pi / 60)/OD.TimeStep_Sec
        FilteredRoll_Rad=AxisWeight\*(FilteredRoll_Rad + math.radians(OD.Inertial.gyro_rate(YAXIS)\* OD.TimeStep_Sec)) + (1-AxisWeight)\*((math.atan(YAxisForGravity_G/ZAxis_G))-OD.XgravityOffsetDegrees)
        FilteredPitch_Rad=AxisWeight\*(FilteredPitch_Rad + math.radians(OD.Inertial.gyro_rate(XAXIS)\* OD.TimeStep_Sec)) + (1-AxisWeight)\*((math.asin(XAxisForGravity_G/TotalGravity))-OD.YgravityOffsetDegrees)
        FilteredYaw_Rad=AxisWeight\*(FilteredYaw_Rad + math.radians(OD.Inertial.gyro_rate(ZAXIS)\* OD.TimeStep_Sec)) + (1-AxisWeight)\* (FilteredYaw_Rad + HeadingRate_Mps\*OD.TimeStep_Sec)
        CentrificalAcceleration_G=(OD.Inertial.gyro_rate(ZAXIS)\*\*2) \* math.sqrt(OD.InertialXOffset\*\*2 + OD.InertialYOffset\*\*2)
        CentificalAngle_Rad=math.atan(OD.InertialYOffset/OD.InertialXOffset)
        PureXaxis=(((XAxis_G \* math.sin(FilteredPitch_Rad)) + (ZAxis_G \* math.cos(FilteredPitch_Rad))) - (TotalGravity\*math.sin(FilteredPitch_Rad))) - (CentrificalAcceleration_G \* math.cos(CentificalAngle_Rad))
        PureYaxis=((YAxis_G \* math.sin(FilteredRoll_Rad) + (ZAxis_G \* math.cos(FilteredRoll_Rad))) - (TotalGravity\*math.sin(FilteredRoll_Rad)\*math.cos(FilteredPitch_Rad))) - (CentrificalAcceleration_G \* math.sin(CentificalAngle_Rad))
        PureZaxis=((ZAxis_G \* math.tan(FilteredPitch_Rad/FilteredRoll_Rad)) - (TotalGravity\*math.cos(FilteredRoll_Rad)\*math.cos(FilteredPitch_Rad))) - (CentrificalAcceleration_G \* math.tan(CentificalAngle_Rad))
        \# Inertial calulations.
        OD.XSpeedLocalI+=((PureXaxis\*math.sin(FilteredPitch_Rad) + (PureZaxis\*math.cos(FilteredRoll_Rad))))\*(OD.TimeStep_Sec\*\*2)
        OD.YSpeedLocalI+=((PureYaxis\*math.cos(FilteredRoll_Rad) - (PureZaxis\*math.sin(FilteredPitch_Rad))))\*(OD.TimeStep_Sec\*\*2)
        OD.XDistanceI=OD.XSpeedLocalI\*OD.TimeStep_Sec
        OD.YDistanceI=OD.YSpeedLocalI\*OD.TimeStep_Sec
        YawWeight=((OD.Xodom.velocity(RPM)\* (OD.OdomWheelDiameter_MM/1000) \* math.pi)/60) / OD.XSpeedLocalI
        \# Motor calulations.
        OD.LDistanceM=((OD.leftEncodedMotor.position()-LeftDegOld) / 360) \* DistancePerDegree_Mpd \* OD.GearRatio
        OD.RDistanceM=((OD.rightEncodedMotor.position()-RightDegOld) / 360) \* DistancePerDegree_Mpd \* OD.GearRatio
        OD.DistanceGlobalM=(OD.LDistanceM+OD.RDistanceM)/2
        \# Slip ratio calculations for comp. filter weight.
        try:
            SlipRatio=OD.Yodom.velocity()/(OD.leftEncodedMotor.velocity(RPM)+OD.rightEncodedMotor.velocity(RPM)/2)
        except ZeroDivisionError:
            SlipRatio=1
        Mtrust=min(max(SlipRatio-0.5, 0.0), 1.0)
        \# Odometer calculations.
        XodomOffset=(OD.Inertial.heading() - OldHeading) \* OD.XOdomOffset/OD.OdomWheelDiameter_MM
        XDistanceO: float=(OD.Xodom.position()-XodomOffset) / 360 \* (OD.OdomWheelDiameter_MM\*math.pi)
        YDistanceO: float=OD.Yodom.position() / 360 \* (OD.OdomWheelDiameter_MM\*math.pi)
        \# Final filtered distance calculations using powered motors and dead wheel odometry.
        OD.XPosition+=(Mtrust\*XDistanceO + (1-Mtrust)\*(OD.DistanceGlobalM\*math.cos(FilteredYaw_Rad) + OD.XDistanceI)) \* math.cos(FilteredYaw_Rad) - math.sin(FilteredYaw_Rad)
        OD.YPosition+=(Mtrust\*(YDistanceO + YawWeight) + (1-Mtrust)\*(OD.DistanceGlobalM\*math.sin(FilteredYaw_Rad) + OD.YDistanceI)) \* math.sin(FilteredYaw_Rad) + math.cos(FilteredYaw_Rad)
        \# Update the old positions for the next iteration.
        OD.Xodom.set_position(0)
        OD.Yodom.set_position(0)
        OldHeading=OD.Inertial.heading()
        wait(10 - (OD.Timer.time()-StartTime), MSEC)
def StartOD(self, Inertial: Inertial, InertialXOffset: float, InertialYOffset: float, InertialZOffset: float, LeftEncodedMotor: Motor, RightEncodedMotor: Motor, RobotWidthMM: float, WheelDiameterMM: float, GearRatio: float, Xodom: Rotation, Yodom: Rotation, OdomWheelDiameterMM: float, XOdomOffset: float, YodomOffset: float) -> Thread:
    self.Inertial = Inertial
    self.InertialXOffset = InertialXOffset
    self.InertialYOffset = InertialYOffset
    self.InertialZOffset = InertialZOffset
    self.leftEncodedMotor = LeftEncodedMotor
    self.rightEncodedMotor = RightEncodedMotor
    self.RobotWidthMM = RobotWidthMM
    self.WheelDiameterMM = WheelDiameterMM
    self.Xodom = Xodom
    self.Yodom = Yodom
    self.OdomWheelDiameter_MM = OdomWheelDiameterMM
    self.XOdomOffset = XOdomOffset
    self.YOdomOffset = YodomOffset
    self.GearRatio = GearRatio
    odometry.calabrate_inertial()
    self.ODT=Thread(odometry.\_Run)
    return self.ODT
def StopOD(self):
    self.ODT.stop()
OD=odometry()
So are you using motor encoders? or am I understanding incorrectly?
