Auton Only Runs if Program Started after Match Starts
Hi,
My team uses pros and okapilib to run our autonomous. Our program works fine on the timed run mode on the controller, but we ran into issues in our last (and first) competition. If we started the program before the field controller started the match, the autonomous wouldn’t run, and the robot was disabled. If we started the code after the match started, the auton would run fine. I have looked through all of my code, along with my team advisor and other team members, and none of us can find the problem.
TLDR: Is there a difference in Pros function execution if the program is started during the match?
We’ll need to see your code to help you. Make sure to put three backtics (```) before and after the code to format it.
#include "main.h"
// SECTION: CONSTANTS
auto startingState = OdomState{1000_mm, -1400_mm, 0_deg};
auto goalLocation = Point{1200_mm, 0_mm};
auto matchLoadZone1 = Point{-1400_mm, 1400_mm};
auto matchLoadZone2 = Point{-1400_mm, -1400_mm};
// SECTION: DEVICE CONFIGURATION
// Okapilib Controller
Controller controller;
// okapilib Chassis
std::shared_ptr<OdomChassisController> chassis =
  ChassisControllerBuilder()
    .withMotors({17, -16}, {-7, 6})
    // blue gearset, 4 in wheel diam, 5 in wheel track (center-to-center distance between the wheels (center-to-center meaning the width between the centers of both wheels))
    .withDimensions(AbstractMotor::gearset::blue, {{15_in, 5_in}, imev5BlueTPR})
    // TODO: SET UP AND TUNE PID??????
    .withMaxVelocity(100)
    .withOdometry()
    .buildOdometry();
// profile controller for autonomous to allow for preplanned routes
std::shared_ptr<AsyncMotionProfileController> profileController =
  AsyncMotionProfileControllerBuilder()
    .withLimits({
      1.0, // Maximum linear velocity of the Chassis in m/s
      2.0, // Maximum linear acceleration of the Chassis in m/s/s
      10.0 // Maximum linear jerk of the Chassis in m/s/s/s
    .withOutput(chassis)
    .buildMotionProfileController();
// end OKAPILIB Chassis
// catapult motors
Motor cat1(-5, true, AbstractMotor::gearset::red, AbstractMotor::encoderUnits::degrees);
Motor cat2(15, false, AbstractMotor::gearset::red, AbstractMotor::encoderUnits::degrees);
MotorGroup catapult({cat1, cat2});
// arm motor group
Motor wings1(10, false, AbstractMotor::gearset::green, AbstractMotor::encoderUnits::degrees);
Motor wings2(19, true, AbstractMotor::gearset::green, AbstractMotor::encoderUnits::degrees);
MotorGroup wings ({wings1, wings2});
// catapult touch sensor (to figure out of it is down)
auto catapultLimitSwitch = ADIButton('A', false);
// intake motor
Motor intake(20, false, AbstractMotor::gearset::green, AbstractMotor::encoderUnits::degrees);
// acorn touch sensor to detect whether or not an acorn is loaded
auto acornLoad = OpticalSensor(5, OpticalSensorOutput::hue, true);
bool wingsOut = true;
pros::ADIDigitalOut matchLoadArm ('H');
// END SECTION: DEVICE CONFIGURATION
// START SECTION: HELPER FUNCTIONS
 * @brief: catapult control function
 * @param: number of times to launch
void launch(int numLaunches = 1, bool aimbot = false) {
  if(aimbot){
    chassis->turnToPoint(goalLocation); // AIMBOT: turn to face the goal
  catapult.setBrakeMode(AbstractMotor::brakeMode::brake); // set the catapult to brake to hold at the bottom
  for (int i = 0; i < numLaunches; i++) { //repeat for the number of times to launch
    catapult.moveVelocity(-100); // move the catapult down
    pros::delay(1000); //wait so that the catapult can launch without hitting touch sensor
    // RELOAD: move the catapult down until the limit switch is pressed
    while(!catapultLimitSwitch.changedToPressed()) { // check if the limit switch is not pressed, meaning the catapult isn't down
      pros::delay(40); //delay not to overload
    pros::delay(5);
    catapult.moveVelocity(0); // stop the catapult when done
void matchLoadAutoLaunch(){
  chassis->driveToPoint(matchLoadZone1); // drive to the match load zone
  // launch acorns as they are loaded
  while(true){
    if (acornLoad.getHue() < 100 && acornLoad.getHue() > 80) { // if it is green
      launch();
    pros::delay(20); // delay to not overload
void alternateWings(){
  wings1.setBrakeMode(AbstractMotor::brakeMode::brake);
  wings2.setBrakeMode(AbstractMotor::brakeMode::brake);
  if(!wingsOut){
    wings.moveAbsolute(0, 60);
  else{
    wings.moveAbsolute(95, 90);
  wingsOut = !wingsOut;
// END SECTION: HELPER FUNCTIONS
// START SECTION AUTONOMOUS ROUTINES
void offensive() {
  // set drivetrain speed
  chassis->setMaxVelocity(400);
  //turn on the intake
  intake.moveVelocity(100);
  //launch the first acorn
  chassis->moveDistance(1500_mm);
  chassis->turnAngle(90_deg);
  chassis->moveDistance(300_mm);
  launch();
  //launch the second acorn
  chassis->turnAngle(180_deg);
  chassis->moveDistance(600_mm);
  launch();
  // grab the team acorn
  launch();
void defensive(){
  chassis->moveDistance(500_mm);
 * Runs initialization code. This occurs as soon as the program is started.
 * All other competition modes are blocked by initialize; it is recommended
 * to keep execution time for this mode under a few seconds.
void initialize() {
	chassis->getModel()->setBrakeMode(AbstractMotor::brakeMode::coast); // chassis braking mode
  pros::lcd::initialize(); // set up screen
  chassis->setState(startingState);
  // set match load arm in
  matchLoadArm.set_value(true);
  launch();
  // autonomous();
 * Runs while the robot is in the disabled state of Field Management System or
 * the VEX Competition Switch, following either autonomous or opcontrol. When
 * the robot is enabled, this task will exit.
void disabled() {}
 * Runs after initialize(), and before autonomous when connected to the Field
 * Management System or the VEX Competition Switch. This is intended for
 * competition-specific initialization routines, such as an autonomous selector
 * on the LCD.
 * This task will exit when the robot is enabled and autonomous or opcontrol
 * starts.
void competition_initialize() {
  launch(1,false);
 * Runs the user autonomous code. This function will be started in its own task
 * with the default priority and stack size whenever the robot is enabled via
 * the Field Management System or the VEX Competition Switch in the autonomous
 * mode. Alternatively, this function may be called in initialize or opcontrol
 * for non-competition testing purposes.
 * If the robot is disabled or communications is lost, the autonomous task
 * will be stopped. Re-enabling the robot will restart the task, not re-start it
 * from where it left off.
void autonomous() {
	//pros::lcd::set_text(1, "Autonomous");
  // matchLoadArm.set_value(false);
  // pros::lcd::set_text(2, "Part 1");
  chassis->moveDistance(35_ft);
  chassis->turnAngle(-2000_deg);
  chassis->turnAngle(-4000_deg);
  alternateWings();
  chassis->moveDistance(-8_ft);
  chassis->moveDistance(8_ft);
  /* FOR GETTING CORNER
  chassis->turnAngle(-1050_deg);
  alternateWings();
  chassis->moveDistance(8.5_ft);
  chassis->turnAngle(1050_deg);
  // int autonSelection = 0;
  // // For our purposes, offensive is when we are on the side with our goal, and defensive is when we are on the side of the other teams goal.
  // launch(1,false);
  // if(autonSelection == 0){
  //   pros::lcd::set_text(2, "Skills: Match Load Auto Launch");
  //   //put down match load bar
  //   matchLoadArm.set_value(true);
  //   intake.moveVelocity(-100);
  //   chassis->moveRaw(600);
  //   // chassis->moveDistance(8_ft);
  //   //turn left 45 degrees
  //   // chassis->turnAngle(900_deg);
  //   launch(15,false);
  // if(autonSelection == 1){
  //   pros::lcd::set_text(2, "Red Offense");
  //   chassis->turnAngle(-45_deg);
  //   intake.moveVelocity(100);
  // if(autonSelection == 2){
  //   pros::lcd::set_text(2, "Red Defense");
  //   // turn right 90 degrees
  //   chassis->turnAngle(90_deg);
  //   // move forward 1.5 meters
  //   chassis->moveDistance(1500_mm);
  // if(autonSelection == -1){
  //   pros::lcd::set_text(2, "Blue Offense");
  // if(autonSelection == -2){
  //   pros::lcd::set_text(2, "Blue Defense");
 * Runs the operator control code. This function will be started in its own task
 * the Field Management System or the VEX Competition Switch in the operator
 * control mode.
 * If no competition control is connected, this function will run immediately
 * following initialize().
 * operator control task will be stopped. Re-enabling the robot will restart the
 * task, not resume it from where it left off.
void opcontrol() {
  ControllerButton runCat(ControllerDigital::L1);
  ControllerButton manRunCan(ControllerDigital::L2);
  ControllerButton runIntakeIn(ControllerDigital::R1);
  ControllerButton runIntakeOut(ControllerDigital::R2);
  ControllerButton IntakeStop(ControllerDigital::X);
  ControllerButton moveMatchLoadArm(ControllerDigital::Y);
  ControllerButton alternateWingsButton(ControllerDigital::up);
  catapult.setBrakeMode(AbstractMotor::brakeMode::coast);
  bool isIntakeRunning = false;
  bool matchLoadArmState = false;
  // tank drive
  while (true) {
    chassis->getModel()->tank(controller.getAnalog(ControllerAnalog::leftY),
                                  controller.getAnalog(ControllerAnalog::rightY));
        // run the catapult when L1 is pressed
        if (runCat.changedToPressed()) {
          launch(1, false);
        // run intake when R1 is not pressed
        if(runIntakeIn.changedToPressed()){
          if(!isIntakeRunning){
            intake.moveVelocity(600);
          else{
            intake.moveVelocity(0);
        if(runIntakeOut.changedToPressed()){
            intake.moveVelocity(-150);
          else{
        if(manRunCan.changedToPressed()){
        if(manRunCan.changedToReleased()){
          launch(1,false);
        if(IntakeStop.changedToPressed()){
        if(moveMatchLoadArm.changedToPressed()){
          matchLoadArm.set_value(!matchLoadArmState);
          matchLoadArmState = !matchLoadArmState;
        if(alternateWingsButton.changedToPressed()){
          alternateWings();
    pros::delay(20);
I’m pretty sure competition_initialize() is the problem. In launch() you have a while loop that holds the execution of the program until the limitSwitch is pressed. I don’t know the hardware of your robot, but if the limit switch is never pressed, the program execution will never continue. The competition_initialize functions sounds like the problem function, but looking at your code the limit switch should be pressed relatively soon. This is my guess, maybe give it a debug.
The problem is that you are calling launch() in initialize(). When the code is started before the match starts, the robot is in the disabled state. This means that the catapult will not move at all. Since the catapult motor is disabled and can’t move, the launch function will loop forever, waiting for the catapult to hit the limit switch. The initialize function blocks all other code, so the launch function looping forever in the initialize function will block all the code. To fix this, simply remove the call to launch in initialize.
I could be wrong, but this sounds very similar to the problem explained in this thread: Competition code and user created tasks. Essentially, if you start your program before you plug in your controller, the program automatically runs your opcontrol function, which starts tasks that control different parts of the robot. Then, when you plug your controller into the field, it goes into the disabled state but does not end the tasks. When the autonomous starts, it tries to control parts of the robot that your opcontrol function was also trying to control, and this interference causes the autonomous to not work.
When you plug your controller into the field before you start the program, the program automatically goes into the disabled function instead of the opcontrol function, so it doesn’t start the tasks. Then, when the autonomous starts, since no tasks had already started, there’s nothing for it to interfere with, so it runs fine.
It doesn’t look like any threads are being started in opcontrol, so this problem shouldn’t be an issue.
