We are on the struggle bus with getting this code to run. This is just a practice one we were playing around with and it runs fine under when started but does nothing under when autonomous. I have searched the forum, chatted with AI and spent a lot of time googling. What are we missing??? Help a second year team out!!
Your code looks correct. Are you running it in autonomous mode on your controller?
Are you connecting it to a smart field for when autonomous? Because that’s the only way that it works. Under when drive it always does it. Under when autonomous it does it when a smart field sends a signal to start autonomous. If you have a spare brain, you can turn it into a smart field controller by downloading a file onto it.
Unless we are compleletly missing something I am not seeing autonomous mode? We have programming skills (which it will not run on) and driving skills but not autonomous?
Okay, that makes sense. No spare brain, we will just download and hope for the best tomorrow at competition. Thank you!! We were trying to remember, will teams select the code from the brain or does it automatically select one?
That’s not really true, in addition to smart field control.
You can use a competition switch connected to the legacy competition port.
You can use legacy field control connected to the legacy competition port.
You can use the timed run triggered from the V5 controller.
Sorry! I am fairly new to vex and thought that was true! I’ll keep that in mind in the future.
Have you tried running it under the “timed run” mode on the controller?
