Battery Clips Question
Does anyone have a replacement for the VEX battery clips? They break all the time and at $6 for 4; I’m unwilling to buy more. Middle schoolers are tough on everything. I’ve been using the battery straps from the older kits. Does anyone have a better solution?
My team just grabs some c-channel and some flat pieces and combine it with screw, spacers, and anything else we can to make some battery holders. They work pretty well during competitions and can be placed on the outside of the robot if need be. The only downsides I’ve experienced is that they can be pretty clunky and require regular maintenance from parts being moved to lock in the battery. Hope this helps.
We use zip ties. They work nicely
zip ties are always good. you should help your students learn to not break things though, lol
C-channels and screws do pretty good. But don’t use long screws (please bless these middle schoolers with the ability to have mechanical consciousness and don’t use the longest screw they can find), I find thumbscrews quite simple (otherwise called specialty screws)
As someone who works with young kids teaching them IQ, good luck @MHeissenbuttel225 :sob:
“pretend this battery clip is your favorite toy. would you want to break it?”
[cue six 8-year-olds bursting into tears simultaneously]
Over the years I’ve had a similar issue with battery clips, and now just tend to ziptie, rubber band, or just have it sit in a secure place.
I would say use a c-channel connected to a rubber band to have the battery slide in and stay put.
Ahhh- My coach’s technique at the beginning of the year is letting us break stuff, and then when it breaks he says, “You fix what you break! Oh well, guess you shouldn’t have broken it!” it tames all of the grade 6’s. and it actually works!
