Best Methods for Alliance Selection
Title is basically the question, but I was just wondering what the best method for alliance selection is, as last time we did it things didn’t go too well (their bot underperformed the whole time and didn’t get us past the first round). Just give me any tips, thanks!
I’d watch some matches of your like top 5 picks. Because it doesn’t matter how good the robot is if the driver isn’t that good. But also look at what your team is good at and bad at. If your team is really good at spinning toggles, then you probably want a team that can score well.
Here’s what we do: once we are approaching around the final match for each team we look for what teams we may want to partner with that are close in rankings to us. We go and meet them and ask them if they would be interested in being in an alliance and about their robot. We ask for a demo, if possible, and also look at one of their matches. Also skills score may be even more important than alliance ranking as that is partly luck for your partners. Also if they are ranked low but seem good we ask why they are low and if it was a mechanical question. We then make a list of who we want to go for, with a few people above and below us. If someone we want above us picks us we accept, if not then we go to the next person we want on the list and so on and so forth. Preferably, you and your top choice agree before hand to pick eachother. Also, if possible, you can pick somebody you have worked with in alliance that you worked well with. If after being in an alliance with someone you may be interested in having a finals alliance, approach them after the match. Hope this helps!
Start very early. Shoot for people around your skill level, or a good team that just hasn’t found an alliance. This is from a pretty shocking scenario when we got turned down by 18 of the 20 teams we asked, and the only two that accepted were lower skill anyways (we were second in the tournament against HIGH SCHOOLERS). In short, aim for people who are in the same boat with alliances and skill.
You want to look at skills, as it’s a fairly unbiased way to figure out which teams have the most technical skill.
However, if you’ve narrowed it down to a couple of options, you should go look at one of their matches to get an idea of how good their driver is–some teams spend a lot of time on their robot, but their driver consequently doesn’t get enough time to practice (case study: me).
Hope this helps:)
(Also most of the time if you have a decent skills score you can always beg a better team to pick you. Nothing to lose right?)
That’s the same strategy that we use
My team has used this and we have been carried through some competitions.
2 words…scorched earth
The main way we choose alliances is to look at build quality, qual rank, matches, and skills. This helps with a lot of alliance selection, but it only applies if you perform well. If you don’t, go for a sister team or just another low rank team.
How would scorched earth work, and would it be good?
