Buying Pneumatics
Part SMC Number Link to site In Stock? Qty
Solenoid Driver N/A, from vex https://store.robotmesh.com/vex-pneumatics-double-acting-solenoid No 2x
Solenoid Driver Cable N/A, from Vex https://www.vexrobotics.com/pneumatics.html?q=&locale.name=English#attr- vex_kit_contents Yes 2x
Tire Pump Fitting - Shraeder Valve With 4mm Tube Fittings N/A, from vex https://store.robotmesh.com/vex-robotics/pneumatics/vex-pneumatics-tire- pump-fitting No 1x
Reservoir, 1-1/2" X 4", w 1/8"NPT & M5 port US14227-S0400 https://www.smcpneumatics.com/US14227-S0400.html Yes 1x
On/Off Switch - Finger Valve VHK3-04F-04F https://www.smcpneumatics.com/VHK3-04F-04F.html Yes 1x
Pressure Regulator - Mini Regulator w/ 4mm Fittings A-474-0000005 https://www.radwell.com/en-US/Buy/SMC/SMC/A4740000005 Yes 1x
"T" Fitting for Valves KQ2T04-00 https://www.smcpneumatics.com/KQ2T04-00.html Yes 1x
Cylinder, Bi-directional - Dbl Acting Cylinder 10mm Bore NCJ2D10-200 https://www.smcpneumatics.com/NCJ2D10-200.html Allow 4 weeks for availability 2x
Solenoid, Fwd, Reverse - 5/2 Single Solenoid Valve, 5VDC SYJ3120-SMO-M3-F https://www.smcpneumatics.com/SYJ3120-SMO-M3-F.html Allow 4 weeks for Availability 2x
Flow Meter - M5 elbow meter out flow control 4mm tubing AS1201F-M5-04T https://www.smcpneumatics.com/AS1201F-M5-04T.html Yes 2x
Fitting for Valves - Fitting 4mm Tubing x M3 Thread KJS04-M3 https://www.smcpneumatics.com/KQ2S04-M3G.html Yes 6x
Fitting for Reservoir - 1/8 X 4mm Male Connector To Reservoir KQ2H03-34S https://www.smcpneumatics.com/KQ2H03-34S.html Yes 1x
Fitting for Cylinders - M5 Male Connector for Cylinders KQ2S04-M5 https://www.smcpneumatics.com/KQ2S04-M5.html Yes 2x
Okay, here is what I’ve got, all formatted in an table. The biggest problem is the solenoid drivers, which are out of stock from vex and robotmesh, and not sold by anyone else.
The quantity numbers are for one double acting kit.
Please let me know if you have any recommendations on other places to buy things, or anything similar.
I am never doing a table like that again.
