Cascade lift using rope
My team Is making a cascade lift with rope and the rope is causing to much tension any tips to remove the tension?
Almost anything rubbing against metal isn’t good. Try adding plastic, or cut some washers in half to reduce friction. Plastic against rope has a lot less friction than metal against rope
my recommendation is to ditch the rope entirely. Any 10 dollar string on amazon or even fishing line will work.
