Good job! Do you have an H-Drive? Also geez, 1 stack in 5 seconds.
No. It’s just regular tank drive.
Holy cow! Nice job! Whats the drive ratio on that?
That kid scored that last stack and said:
I would like to transfer you to my team once you get into VRC.
Trust me this took a lot of effort. When your trying to stack you should never worry if the stack it going to fall or not. You should just focus on driver fast and smooth.
100% agreed
Please don’t revive dead threads
Honestly, I wouldn’t consider this thread dead (it’s less than a month old).
Yeah but it was untouched for 2 weeks…
two weeks is not even close to a year for it to be locked
i consider nearly locked as a dead thread
Also, Live Remote Tournaments use a different field setup(this setup is skills), but nice job!
and it is correctly labeled as a Driver Skills run in the title.
This is a skills run, using the skills field setup.
How do you do in teamwork?
Reviving it to add nothing substantive to the discussion isn’t helpful to those on the forum. People are coming to this post for a reason. Misc Moon men should be in their own thread.
But if you could revive something on-topic instead of making a whole new thread and cluttering the forums, reviving a thread that’s less than a month old seems like the better option.
Yes. But the better option is to use the search bar and read the whole topic (unless it’s like darkest vex memes and over 1700 posts long, in that case use ctrl-f), and see if anything applies. If not, then it is okay to post.
Edit: this is a little out of context with the posts above, I meant if you have a programming or robot problem
