Hi guys,
I’ve been trying to find a way to change up our driving controls to give us more precise and intuitive control using split-arcade without switching over to tank drive. I was reading through articles on both the forum and the Sigbot’s Wiki page when I stumbled across the Cheesy Drive code. I searched through forum for any examples on the coding, specifically for python, but I found none for any type of coding. Based off of the short C++ example on the Wiki, I tried to code a version that, when uploaded, allowed the robot to move forwards and backwards at about 10% velocity. However, it had none of the Cheesy Drive functionality, and would only turn about half of the time when moving the joystick. Below I have my code. Any suggestions on how to fix it, or if there’s something I missed, would be greatly appreciated.
Thank y’all so much,
-11865A
# --- Cheesy Drive + Stop Logic for Controller 1 ---
DEADBAND = 5 # joystick deadband in %
SLEW_RATE = 4.0 # max % change per loop (~50ms loop → 80%/sec)
# Track last outputs for slew rate limiting
last_left_speed = 0.0
last_right_speed = 0.0
def apply_deadband(value, deadband):
"""Zero out small joystick values."""
return 0 if abs(value) < deadband else value
def clamp(value, min_val, max_val):
"""Limit value to a range."""
return max(min_val, min(max_val, value))
def slew_limit(target, last, rate):
"""Limit acceleration per loop."""
delta = target - last
max_change = rate
if delta > max_change:
return last + max_change
elif delta < -max_change:
return last - max_change
else:
return target
def cheesy_drive(throttle, wheel, quick_turn):
"""Cheesy Drive core algorithm."""
sensitivity = 0.85
over_power = 0.0
if quick_turn:
over_power = 1.0
angular_power = wheel
else:
angular_power = abs(throttle) * wheel * sensitivity
left_output = throttle + angular_power
right_output = throttle - angular_power
# Clamp outputs to safe range
left_output = clamp(left_output, -100, 100)
right_output = clamp(right_output, -100, 100)
return left_output, right_output
# --- Main Controller Loop ---
def rc_auto_loop_function_controller_1():
global drivetrain_l_needs_to_be_stopped_controller_1
global drivetrain_r_needs_to_be_stopped_controller_1
global controller_1_left_shoulder_control_motors_stopped
global controller_1_right_shoulder_control_motors_stopped
global remote_control_code_enabled
global drivetrain_left_side_speed, drivetrain_right_side_speed
global last_left_speed, last_right_speed
while True:
if remote_control_code_enabled:
# Stop motors if inertial is calibrating
if drivetrain_inertial.is_calibrating():
left_drive_smart.stop()
right_drive_smart.stop()
while drivetrain_inertial.is_calibrating():
sleep(25, MSEC)
# --- Read joystick inputs ---
throttle = apply_deadband(controller_1.axis3.position(), DEADBAND)
wheel = apply_deadband(controller_1.axis1.position(), DEADBAND)
quick_turn = controller_1.buttonL1.pressing() # Quick turn button
# --- Cheesy Drive math ---
drivetrain_left_side_speed, drivetrain_right_side_speed = cheesy_drive(throttle, wheel, quick_turn)
# --- Apply slew rate limiting ---
drivetrain_left_side_speed = slew_limit(drivetrain_left_side_speed, last_left_speed, SLEW_RATE)
drivetrain_right_side_speed = slew_limit(drivetrain_right_side_speed, last_right_speed, SLEW_RATE)
# Save for next loop
last_left_speed = drivetrain_left_side_speed
last_right_speed = drivetrain_right_side_speed
# --- Left side control ---
if drivetrain_left_side_speed == 0:
if not drivetrain_l_needs_to_be_stopped_controller_1:
drivetrain_l_needs_to_be_stopped_controller_1 = True
else:
drivetrain_l_needs_to_be_stopped_controller_1 = False
left_drive_smart.set_velocity(drivetrain_left_side_speed, PERCENT)
left_drive_smart.spin(FORWARD)
# --- Right side control ---
if drivetrain_right_side_speed == 0:
if not drivetrain_r_needs_to_be_stopped_controller_1:
drivetrain_r_needs_to_be_stopped_controller_1 = True
else:
drivetrain_r_needs_to_be_stopped_controller_1 = False
right_drive_smart.set_velocity(drivetrain_right_side_speed, PERCENT)
right_drive_smart.spin(FORWARD)
