void opcontrol() {
pros::Controller master(pros::E_CONTROLLER_MASTER);
pros::MotorGroup left_mg({-1, 2, 3}); // Creates a motor group with forwards ports 1 & 3 and reversed port 2
pros::MotorGroup right_mg({4, -5, 6}); // Creates a motor group with forwards port 5 and reversed ports 4 & 6
while (true) {
pros::lcd::print(0, "%d %d %d", (pros::lcd::read_buttons() & LCD_BTN_LEFT) >> 2,
(pros::lcd::read_buttons() & LCD_BTN_CENTER) >> 1,
(pros::lcd::read_buttons() & LCD_BTN_RIGHT) >> 0); // Prints status of the emulated screen LCDs
// Arcade control scheme
int dir = master.get_analog(ANALOG_LEFT_Y); // Gets amount forward/backward from left joystick
int turn = master.get_analog(ANALOG_RIGHT_X); // Gets the turn left/right from right joystick
left_mg.move(dir - turn); // Sets left motor voltage
right_mg.move(dir + turn); // Sets right motor voltage
pros::delay(20); // Run for 20 ms then update
So this is my program in vex PROS so my wheels they move barely but when I unplug two motors all then the wheels move so i have switched if its reversed or not many times but it isnt working so i did the same program in vex blocks it works can someone figure my problem out. Thanks
