Whenever I try to compile code in the PROS Editor, I get the following error message:
-n Adding timestamp
-e \x1b[32;01m[OK]\x1b[0m
-n Linking project with libpros,okapilib
-e \x1b[31;01m[ERRORS]\x1b[0m
/usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/bin/ld: /usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/lib/libstdc++.a(cxx11-ios_failure.o): in function (anonymous namespace)::__io_category_instance()': cxx11-ios_failure.cc:(.text._ZN12_GLOBAL__N_122__io_category_instanceEv+0xc): undefined reference to __sync_synchronize’
/usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/bin/ld: /usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/lib/libstdc++.a(locale.o): in function std::locale::_Impl::_M_install_cache(std::locale::facet const*, unsigned int)': locale.cc:(.text._ZNSt6locale5_Impl16_M_install_cacheEPKNS_5facetEj+0x18): undefined reference to __sync_synchronize’
/usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/bin/ld: /usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/lib/libstdc++.a(locale_init.o): in function (anonymous namespace)::get_locale_mutex()': locale_init.cc:(.text._ZN12_GLOBAL__N_116get_locale_mutexEv+0xc): undefined reference to __sync_synchronize’
collect2: error: ld returned 1 exit status
make: *** [bin/monolith.elf] Error 1
Error: Failed to build
This happens for whatever I try to compile. I doubt its an issue with the actual code since my other teammate can compile fine from his laptop. Any suggestions for a fix would be appreciated. Thanks.
