Compression + tilter issue
the problem isn’t the tilter, it’s the rollers intaking. I haven’t seen anyone do this but I think you could make the rollers more alligned with the tray by putting them on the top instead of the bottom.
He did in fact state that he had problems with his tilter.
oh, I should probably read the thread properly. :sweat:
All good. I got the roller issue fixed
what did you do? Do you have pictures/videos? Just asking because I’m working on same kind of thing and wondered if you had tips.
PM me if you have issues with building. I’ve gone through more than I can count. Also I changed motors to 100rpm
Why did you change to 100rpm, just for torque? How was the speed difference, did it have any major impact?
Its half, but it worked. The issue was torque. PM me for this bc I dont want to fill up forum
ok sorry, how do I do that lol
Click on someone’s profile picture then hit “message”
Just an update: 9cube - YouTube
We experienced the same problem with our design which is very similar to your vertical flip-out (I presume you throw you intakes out vertically at the beginning of the round). With our team, we attached stand-offs to the bottom of the intake and a little barrier block at the bottom which allow the intake to fall in when the lift is down, restricting horizontal spread that causes your issue of compression. So far this got us 8 max cubes so I highly recommend switching to fixed intakes if you have time as they solve compression at the cost of longer intakes.
I have compression down fine
Did you make any changes besides the 100rpm motor switch before the last update video?
I didn’t
Wow. Thats quite impressive how much more effective the 100 rpm motors are.
  1. Wth is up with your arms? Find some way to brace then so they don’t spread apart so much. Curretnly they are like this / \ braceto make them like this I I . Ive seen this with so many teams. At a point your arms will be biggest loss of compression. Next up. your intakes are going way too fast. Slow them down. I doubt your bot is gonna get a 100+ skills score so there is no need for an intake that fast.
    C’mon ziptie your motors for god’s sake.
I have a brace on the arms.
Idk man brace it more. I really feel you should redesign your arms to be parallel to each other
I’ll edit this post later when I find the post but there was a design on Instagram where a team put a set of c channels on either side of the arm that were given only a slight amount of force to pull them down. When the intake swung in, it pushed the c channels up, and then when it was between the channels they were pulled down around the intake, this is what I did to my bot, and it looks like the majority of my compression issues have been eliminated so far.
