Its called. The one and only. SUper big brain reliable. CHAIN LINKS
Oh my, How did I forget about chain links, Especially the low strength ones. The normal ones donāt fit well in the holes.
ExaCTLy. They should add new once that are about an in ch smaller. way more convenient for winning matches.
What about the push pins. They are way faster than the chain, as long a you donāt use the bearing flats.
chains still original. cant beat that
This entire little conversation (
) and the rest
belongs in What is the worst advice you could give?
I know Iām a bit late to the counterweight discussion, but what you really need to do is rubber band high strength shafts inside U-Channel.
Or the old hex screws you never use.
This is how it is done.
true, but the star inserts on the shaft collar is too shallow, so it is vulnerable to stripping
Take that, world renowned scientists! we will create neuclear fusion with vex parts!
would be fascinated in seeing how many matches would be played(before iminent world destruction), who would be willing to host a tournament and which region/country would be the first to create a fusion-ing robot.
9.5/10 , looking forward to seeing this design play out!
That moment when you need to use someoneās hotspot at a comp to download your program
Also, why is there no light mode for vexcode iq!?!?
Are you implying you want to use light mode?
Dark mode. I made a typo
Ok good. I was getting worried. Also if you had answered āYesā I was planning on screenshotting this conversation and putting it in cursed images.
