Dankest Vex Memes?
When a ring gets in the way of your auton
This is truly the best vex meme no one can top this because its drow the master sensei of the forums
@Kajunii42 you have been bested
You don’t have a chance, Mike.
BUUUURRRRRRRRRNNNNNNNNN
When you walk into a meme war
Pov: you say drow inst the gdc
It is inevitable
When the builder tries to correct you on programming
The Programmer:
Lord Of The Rings Probably
At a comp and you get allianced with a clawbot and you tell him to defend
The Clawbot:
Quadcopters, RC Robomaster Robots, Spot Robot, and XBox/Playstation videogames usually follow a similar control scheme where usually the right joystick horizontal is used for turning, left joystick vertical is for moving forward and back (or the left joystick entirely is for lateral movement, with right joystick for rotational).
Mans just entered into the crossfire of a meme war
I need to finish this war I USE THE ULTIMATE WEAPON DROW AND HIS BANHAMMER:
When you leave the form for an hour and find this:
The meme war may have been revived by this one quote:
and this:
and then Drow was like:
When you win a 1v2 by parking with 3 goals and scoring 30 points in rings:
